USB-Cable
DJ1YG
Member ✭
Hi all,
I was fascinated about the new USB cable option and hoped to finally succeed in connecting my tuner to my 6700 radio after several attempts with DUtil failed. The tuner is as old as my Yaesu FT 2000 and the two worked together perfectly using the BCD band data A, B, C and D supplied by the Yaesu trx. The tuner is a Hamware AT-402 unit.
To connect my 6700 and the tuner I would prefer to use the FTDI USB to serial Cable DB9M but the USB-Cable Interface Guide does not address the 4 pins of the DB9M providing the 4 BCD signals.
Any idea? Thank you
vy 73, Dieter, DJ1YG
Dieter, You must use a bit cable like this one sold by Flex or other distributors. https://www.amazon.com/FTDI-C232HM-EDHSL-0-Assembly-USB-MPSSE-Output/dp/B00HKK4PUE/ref=sr_1_1?ie=UTF8&qid=1481654883&sr=8-1&keywords=ftdi+i2c+cable . Look at the USB guide and you'll use wires 2, 3, 4, and 5 to your own connector. Set the USB on the Flex to BCD. It'll work. 73, Mack W4AX Alpha Tester0
I believe you would need to use the USB to Parallel cable. Here is the link...
http://cart.flexradio.com/USB-to-Parallel-adapter-for-the-FLEX-6000-series_p_1001.html
This is the link with the data to use the cable...
http://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/?_ga=1.249011335.1678774256.1417055...
Jon...kf2e0 -
what exactly IS the deal with this "usb cables" thingy in the newest beta release ? whats it for ?0
Hi Rob,
The purpose or difference with the new radio USB support is that you can now control your station peripherals without using a PC for the connections. The connection is made directly from the USB ports on the back of the radio. Previously many folks used a program like DDUtil that runs on the PC, connects via the CAT program and uses the COM ports on the PC.
There is support for both serial (DB9) connections and parallel (BCD) connections with the new USB radio ports. I was using DDUTil and the PC serial (com ports) to control my amplifier and antenna switch. I changed my setup to use the Radio USB ports. In my case both peripherals just need frequency data. If you are using a peripheral that requires other command logic (like a SteppIR antenna) you can still use the new USB port but it won't support the commands like 180 reverse, etc. So unless / until FRS adds specific control support some folks will want to stay with the DDUtil type control.
I used both the serial and BCD methods and documented the setup and wiring on my web page:
http://www.nn4zz.com/FLEX6700.htm#Setup_and_testing
Hope this helps...
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
SSDR / DAX / CAT/ 6700 - V 1.10.8
Win10
Al
Excellent description.
Tim VE6SH
Al, It's my understanding that DDUTIL can use the USB Comm cables attached to the radio also as COM ports via SmartCAT; therefore, still being able to remotely using a laptop.0
Hi Mike / WA6FXT
I didn't see that feature mentioned anywhere but I haven't been looking at the remote operation aspects. Also I don't see anything but PC COM ports listed in DDUtil drop down boxes. Is there documentation on how to set this up somewhere?
Regards, Al / NN4ZZ
Win10
Al - your question would be better served for the Community if you would create a new topic for the DDUtil question.0
Done.
https://community.flexradio.com/flexradio/topics/can-ddutil-access-the-new-radio-usb-ports
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com0 -
Thanks Al.0
One advantage that is overlooked for the serial cable feature is that it's possible to now assign CAT data by antenna port and not just by slice. This was not in DDUtil, at least not that I saw. DDUtil forced you to the TX slice, always and it only really was useful on one port. This didn't work for some SO2R setups or more complicated setups with antenna switches and tunable antennas (eg SteppIR).
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 767 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
