Microphone Profile Chages
Jose B Rivera
I want the DefaultPR781 to be my Microphone Profile. So I pick it. I then go to Profile Manager and click on the Transmit Tab to save my transmit settings along with this microphone profile.
I name the new transmit profile Default2 and save it. At this point the Transmit Profile picked on the RF panel to the right says Default2 and my Microphone Profile says DefaultPR781. I then go to the Global Tab of the Profile Manager type in a new profile name called Default2. I save it. I then look at my microphone profile and instead of reading "DefaultPR781" it reads Default2. I don't understand this. Why does it still not read DefaultPR781? It's confusing. I don't understand what is happening in this situation.
Jose
Other than the mic profile name "Default2" is there any difference between the Default2 and the DefaultPR781 profiles? I'm not sure what's causing the name change, might be a persistence issue.
If you reload the Default2 Global profile again, does it still load the Default2 mic profile? I've sometimes had to save, and then reload the global profiles to verify what's actually being selected.
SDRgadgets73, Jay - NO5J
The instructions are in the Flex Manual. However, it goes like this.
After the radio is on, go to Profile - Save Mic Profile - have your EQ settings for your Mic ready on the drop menu ProfilManager - go to Microphone - Insert your new mike Name Pr781 ... Load it and them Save it...
That's it!
Jose
Additionally:
Global profiles store the selected Transmit and Mic profiles.
Transmit Profiles don't store Mic profiles. They are associated with Antenna selections.
Mic profiles store and are also triggered by the mode in the active TX slice.
If you had more than one slice open when you were saving the profiles, maybe the active Transmit slice got switched to another slice that had a different mode or Antenna selected at the moment you saved it.
If that happened Persistence would switch the mic profile name when it saw the active slice switch.
I've saved several multi-slice but single panadapter global profiles, and sometimes have to delete the last save and try again, due to persistence getting in the way.
Persistence keeps track of what mic profile gets selected when the mode changes.
So sometimes it's a combination of stored profile settings and persistence, that determines the end result.
When it doesn't work delete whatever you just tried to save and try again. And always try to avoid having persistence store mistakes, to clear the stored persistence values you have to perform a factory reset, or play around until you "accidentally" stumble onto something that corrects the persistence mistake.
Persistence can be a blessing or a curse at times.
Hi Ernest, I think you are describing know how to create a mic profile. But I can do that. My confusion came when a Global profile changed the mic profile. I am getting confused as to how profiles work with each other. And how clicking on a Global profile gives me results I did not expect.
All I want to do is have a SSB Profile with the mic of my choosing and Digital Profiles for those modes. I have the digital profile down pretty good (though I still have to click on the DAX which exists outside SmartSdr).
But I have to figure out the SSB profile so I can then move from band to band without the mic profile changing on me.0 -
In later versions of software beyond 1.6, the Mic Profile is linked to the Mose, not the Transmit profile. Whatever Mic Profile you last used is linked whenever you go back to that mode. Except...when you save a new transmit Profile, it also saves a copy of whatever Mic Profile you are using, but saves it under the same name as the Transmit Profile you just saved. If you don't want the new Mic Profile, delete it. Then use your favorite Profile. When you come back to that mode, the last Mic Profile you used with that mode should be remembered.0
Ken, if saving a Transmit Profile saves the current Mic Profile does it also reload that Mic Profile when you load that Transmit Profile? That may be part of the confusion. I'm going to reread the manual yet again and draw myself a profile tree! Has anyone already done that?0
- 392 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 210 DAX
- 387 SmartSDR API
- 66 Aurora
- 309 FLEX-8000 Signature Series
- 979 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
