Has anyone configured a USB cable to work with 1.10.8 and a Yaesu Quadra amp?
Jim Runge
Jim,
Yes, I have. You can get the info at this link.
https://dl.dropboxusercontent.com/u/20979885/Quadra%20to%20a%20Flex%206500.pdf
Jon...kf2e0 -
I have not yet tried setting it up with a FTDI to BCD cable. Just the old fashioned way:)
Jon0 -
I would use an FTDI Bit cable from the back of the radio directly to the amp. Use this cable http://www.mouser.com/Search/ProductD... . Set the cable in SmartSDR to HF BCD. Use wires 2, 3, 4, 5 to pins 4, 5, 6, 7 respectively on the Quadra (use the DB15 or the 8 pin DIN). That's it!
Mack
W4AX
Alpha Tester0 -
I will check it out. Would rather not have to use DDutil.
Thanks;
Jim0 -
That is what I am lookinf for. Thanks; Jim0
The problem with this is you only get band data. You can't set drive levels like you can with DDUtil. It comes down to what is more important to you...operating with no computer or having more functionality.
Jon...kf2e0 -
Understand Jon. Thanks. Jim0
W4AX said: ..."Use wires 2, 3, 4, 5 to pins 4, 5, 6, 7 respectively on the Quadra (use the DB15"...
What are the colors of those wires (2. 3....) Looks like NOT the standard color codes.
Also, gnd is probably needed at pin 15 on the db-15. Which colored wire is gnd?
Jerry W4UK
2-Orange 3-yellow 4-green 5-brown Gnd-black. All this info is in the data sheet.
http://www.mouser.com/ds/2/163/DS_C232HM_MPSSE_CABLE-10602.pdf
have fun!
Mack
W4AX
I am about to order this cable as well. I would prefer to use DDutil... however am not finding a Parallel PCI card that is Windows 10 compatible. The one that is currently in my computer worked great with XP and my Flex 5000... but it has no drivers available for Windows 10 64 bit. Does anyone know of a windows 10 compatible PCI card? I am running out of solutions.0
- 691 The Flea Market
- 197 SmartSDR+
- 461 SmartSDR for Mac
- 113 Aurora
- 976 Genius Products
- 483 Power Genius XL Amplifier
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
