SmartSDR v3.3.29 and the SmartSDR v3.3.29 Release Notes | SmartSDR v2.7.6 and the SmartSDR v2.7.6 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
DAX I/Q level is too high comming out of stream for feeding MAP65. Can I adjust it?
Paul Sokoloff
Have you tried to adjust it in DAX on the Slider in RF streams?0
Thanks for your reply. RX streams is for audio only.
IQ streams does not have a slider. Cannot find any level control for that parameter.
Paul
I am sorry, I misread.0
The DAXIQ output is fixed for a 0 dB output gain level. There is no way to change the gain level (volume) of the DAXIQ channel.0
I went into "DAX RESERVED IQ RX 1" and lowered the levels to 25%. I also unchecked "applications exclusive control" There is no difference in the level noted in MAP65.0
Never use or change any the reserved DAX audio devices. Only change the ones that are not labeled reserved.0
Also note I changed from MME to WDM and still no change.0
OK went into Sound tab and then into Recording tab. That is the only place I found a DAX IQ 1 non reserved device. I had changed that and no change in map65.
Do I need to reboot after change?0
You shouldn't need to reboot. I'll need to investigate why the gain is fixed and not adjustable in the Windows sound device properties.0
Is there an update on this? I'm thinking I would like to adjust the level coming into CW skimmer to reduce it's sensitivity to noise. Some nights with few signals I'm running 2500 decoders while skimmer tries to decode noise.
Or maybe there's an adjustment within skimmer I've missed.0 -
The gain if fixed because the DAXIQ comes out of the FPGA and there is no facilities to reduce it. Also, I run CWSkimmer, SDR-Bridge and a 6700 several times a week and I do not see this behavior at all. I suspect that there may be something set in CWSkimmer that is causing this behavior.0
It seems to be the noise level causing it which is why I was hoping to back it down a little bit. Here's 80 meters this morning. The difference as I can tell is the noise level is down quite a bit this morning. I'll check with the author and see if I'm missing something there.
Check the decoding thresholds and if you are only viewing verified calls in CW Skimmer.0
I have Verified Calls + Show 599 checked. I see no place to adjust decoding thresholds. Just sent an email to Alex and will post if he has a solution.0
Alex's response:
There is no point in adjusting the I/Q level, unless it is so high that the signal is clipped. CW Skimmer looks at the peaks above the noise floor so multiple yellow circles mean that there were multiple peaks rather than the usual wideband (flat) noise.
Hmm. Not sure what to make of it but it seems to be like this by design.
Thanks for checking Tim.
Kev
I have a similar issue with the DAX IQ level into MAP65. In my case it is too low. On 2M EME it reads about 13% in the MAP65 level display and they recommend a level at 20-30%. Is there a way to increase the DAX IQ level?0
The level for DAXIQ is fixed.0
Is there a standard for I/Q? Is it always fixed or is it FRS's implementation? If it is just an implementation issue can we turn this thread from a question to an idea?
K0
- 18.3K All Categories
- 126 Community Topics
- 2K New Ideas
- 275 The Flea Market
- 6.2K Software
- 5.3K SmartSDR for Windows
- 90 SmartSDR for Maestro and M models
- 204 SmartSDR for Mac
- 185 SmartSDR for iOS
- 179 SmartSDR CAT
- 109 DAX
- 319 SmartSDR API
- 7.8K Radios and Accessories
- 6.3K FLEX-6000 Signature Series
- 627 Maestro
- 29 FlexControl
- 769 FLEX Series (Legacy) Radios
- 396 Genius Products
- 237 Power Genius XL Amplifier
- 141 Tuner Genius XL
- 18 Antenna Genius
- 114 Shack Infrastructure
- 71 Networking
- 200 Remote Operation (SmartLink)
- 87 Contesting
- 290 Peripherals & Station Integration
- 86 Amateur Radio Interests
- 569 Third-Party Software
