Radio chooser screen is missing in Maestro 1.9.13
How did you switch off your Maestro? Short press or long press power ON/OFF button? Press long till a split screnn came up 73 Chris0
... or check here: https://community.flexradio.com/flexradio/topics/maestro-no-radio-shown0
First I tried the long press and then tried the short press. Neither worked.0
Let's see:
Long button press for power off,
Short button press for power off,
WiFi enabled, Ethernet cable enabled
WiFi disabled, Ethernet cable enabled
WiFi enabled, Ethernet cable off
Still see 1.9.9.20, 1.9.9.19, 1.8.4.18 1.7.32.15 but no 1.9.13.anyting
Radio and computer updated correctly.
Maestro is now unusable. Is the Maestro update service running? Anybody used it today? Flexradio.com for downloads is OK.
The Maestro is starting up and connecting to last known radio. To get to the WiFi or radio chooser, press Menu, Network, then WiFi Settings.
Dave, can you explain the rationale for this? For my money, selecting a radio should either be as before, or, on the fly from the Radio tab under the Menu button.0
I am only guessing on reason but it makes sense. If you have one radio/one Maestro and use it in same location wouldn't you want it to boot directly to the last version and network that you were connected to and auto start the radio? Saves time on startup.
Again you can go to Menu/Network/WiFi Settings to change WiFi or radio.
Just my thoughts.... Dave wo2x
I do not know how it would behave when both radios are on the network with same version software. My 6500 is out on loan and I can try that theory when I get it back (on the 6700 now)
I am a new Maestro user but in the little time I've spent with it, 1.9.9 always started up with the Network chooser, then the Radio chooser, where both radios were listed and I could choose either. But again, my suggestion would be to permit changing radios on the fly.0
See how it works when you upgrade the second radio to 1.9.130
And there's the rub. I'll have to do it manually.0
Turn off the radio running 1.9.13 and turn on the radio running 1.9.9. Boot Maestro it should then show the 1.9.9 radio The Maestro should show the radio in radio chooser and have an icon next to it indicating the radio will need a firmware upgrade. You can then upgrade it.0
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
