Flex 6700, N1MM Logger+, Ctrl+Enter, or Ctrl+Fn
I use the following feature of N1MM Logger+ in my current
SO2R setup, described in Paragraph 2.8.2.6.3 of the N1MM Logger+ online documentation:
“Ctrl+Enter, or Ctrl+Fn - Using these commands will send the corresponding message on the alternate radio; with the alternate radio defined as the radio that does not have RX focus.”
This a highly desirable feature for effective SO2R.
I am unable to get this feature to work consistently with my Flex 6700. I only occasionally see the TX slice change and I always get the following information pop-ups: “SmartSDR The antenna may not be changed while transmitting” and "SmartSDR Transmit Slice has not been selected."
The only way I can reliably switch from TX Slice A to B (and vice-versa) using N1MM+ is by using Ctrl+left or right arrow.
Related to the above, the Dueling CQ feature of N1MM Logger+, described in Paragraph 2.8.2.3 also exhibits similar behavior.
I am not sure if this is an issue with the Flex 6700 or N1MM Logger+. I have also submitted a N1MM Logger+ bug report.
73, Bud AA3B
I solved this issue. The fix was to go the N1MM Logger+ Configurer and increase the PTT Delay for the Winkey. I set it at 350 msec and all seems to be working now.3
Bud
I have tried to duplicate this issue. My Winkey PTT delay is at the default setting of 30ms. I can't duplicate the problem. I am able to send to the "other" radio anytime. It is almost instant.
I don't use Pause to switch focus but tried it and it worked all the time. I normally use CTRL Left and Right.
Maybe we should discuss this on the phone....
73, Craig K9CT0 -
I also was unable to duplicate the issue. If Craig hasn't already helped you solve this on the phone, I would recommend going through the 6700 SO2R doc linked here: http://www.flexradio.com/downloads/so2r-mode-with-n1mm-for-the-flex-6700-how-to-guide-pdf/0
My understanding is the K9CT has been able to reproduce the problem. Thank you.
The loop is being closed on these issues. I dont think its gonna be an issue much longer. :-)
It's still an issue here prepping for 2021 Summer NAQP RTTY. Playing with delay times, but it still happens occasionally.0
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 251 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 214 FLEX-8000 Signature Series
- 922 Maestro
- 895 Genius Products
- 324 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 975 Third-Party Software
