Flex 6700, N1MM Logger+, Ctrl+Enter, or Ctrl+Fn
I use the following feature of N1MM Logger+ in my current
SO2R setup, described in Paragraph 2.8.2.6.3 of the N1MM Logger+ online documentation:
“Ctrl+Enter, or Ctrl+Fn - Using these commands will send the corresponding message on the alternate radio; with the alternate radio defined as the radio that does not have RX focus.”
This a highly desirable feature for effective SO2R.
I am unable to get this feature to work consistently with my Flex 6700.  I only occasionally see the TX slice change and I always get the following information pop-ups: “SmartSDR The antenna may not be changed while transmitting” and "SmartSDR Transmit Slice has not been selected."
The only way I can reliably switch from TX Slice A to B (and vice-versa) using N1MM+ is by using Ctrl+left or right arrow.
Related to the above, the Dueling CQ feature of N1MM Logger+, described in Paragraph 2.8.2.3 also exhibits similar behavior.
I am not sure if this is an issue with the Flex 6700 or N1MM Logger+.  I have also submitted a N1MM Logger+ bug report.
73, Bud AA3B
  • Bud Trench
    Bud Trench Member
    edited October 2016
    I solved this issue.  The fix was to go the N1MM Logger+ Configurer and increase the PTT Delay for the Winkey.  I set it at 350 msec and all seems to be working now.
  • Craig K9CT
    Craig K9CT Member ✭✭
    edited February 2017
    Bud
    I have tried to duplicate this issue. My Winkey PTT delay is at the default setting of 30ms. I can't duplicate the problem. I am able to send to the "other" radio anytime. It is almost instant.
    I don't use Pause to switch focus but tried it and it worked all the time. I normally use CTRL Left and Right.
    Maybe we should discuss this on the phone....
    73, Craig K9CT
  • Eric-KE5DTO
    edited December 2016
    I also was unable to duplicate the issue.  If Craig hasn't already helped you solve this on the phone, I would recommend going through the 6700 SO2R doc linked here: http://www.flexradio.com/downloads/so2r-mode-with-n1mm-for-the-flex-6700-how-to-guide-pdf/
  • Bud Trench
    Bud Trench Member
    edited October 2016
    My understanding is the K9CT has been able to reproduce the problem.  Thank you.
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    The loop is being closed on these issues.  I dont think its gonna be an issue much longer. :-)
  • W7IV
    W7IV Member
    It's still an issue here prepping for 2021 Summer NAQP RTTY. Playing with delay times, but it still happens occasionally.
