SmartSDR v1.9.9 released. Can SmartSDR 2.0 be coming next?
Arnie
Just stirring the **** a bit.
73 de Arnie W8DU
73 de Arnie W8DU
2
It sure would be nice to get this considering the features have been promised for over a year now.0
Actually, I think we are getting a 1.10 before 2.04
I am still looking for more features under version one. So I hope they keep coming.
Cheers
Oh I certainly hope so, but it had better be good!
I am really hoping that it has all the prerequisites that should have been there from the v1.02 -
Well, there can always be a v1.9.9.1 if they need to add something prior to the big release of 2.0. I do hope one can adjust the sizing of the waterfall and panadapter, as well as tweak colors for those with visual impairments, with 2.0.
I suspect what will happen in Flex will continue with the 1-series until two things occur first until they get 1.x correct where correct is something between what they envisioned it being and what the user base envisions it being and number two and perhaps more importantly wait until they're within say 6 months of a 2.0.0 release because if they've learned anything it's people here are like really really bad about holding their breath and their water.0
I'm betting 2.0 has a great squelch so we can put all those slices to full use without going deaf from the noise mix.3
Amen to the need for squelch !!! It should have been included from the get-go. I don't think anyone expected SmartSDR to be less smart than PowerSDR, even 4 years after SmartSDR was first released.0
Squelch, band edge markers, working ANF, Band Data from radio, and a few others I am also hoping that will be part of the final 1.x release.4
Not a fair comment, I think. The idea of buying a Flex is to grow with it over time as features change. SSDR is extremely complicated and far more advanced then PSDR. I know you guys would not move to another kind of radio, you would have done so by now with all the complaining about SSDR not fully complete in you eyes.2
The way I see it is this is a joint effort between the MFG and the end users. Our real world experience and feedback helps the software people make a good rig even better.
Yes, I've mentioned that the NR & ANF should be improved. I'm sure they will be in time. It must be hard to prioritize improvements & new features, when everyone wants something different, all at the same time.
At least this is a situation where it's getting better one way or another on every new release. Gives us something to look forward to.. Works for me, I like my constantly evolving Flex 6500!
It looks like it will be 1.9.x going to 1.10.x after that up to maybe 1.99.x then 2.00.x
Depends on where they put the decimal points.
The numbers game.Bringing more improvements.
Don't care if its 2. 3. or 4. or even I have to pay for it, just give us the pure signal you promised ...!!
A good point Phil, it is certainly a collaborative joint development, and one where the long-standing patient userbase deserves more information and input to the process than just this apparently one-way forum.
A serious question: has anyone compiled a comprehensive list of what we the userbase are in fact expecting as "must-haves" from v2.0?
If not, we really should do this so that it can act as the benchmark to help dicide on if/when to part with dollars...
Things may work a little different after V.2.0
They likely will have feature sets for sale, and if we like them we can buy them. I would think they already have a list of things planed. But I suppose it would not hurt to put in a request.0 -
FRS has already stated that Adaptive Pre-Distortion is in the plan. They designed the hardware to support it from the beginning. But they have other features that are higher on the priority list to add or perfect first.0
And as none of the newer up coming SDR radios don't have it either?0
I want a good mix of common sense features, smooth operation improvements and WOW factor features.
Since FDX I have not had a "WOW factor" feature. Well, maybe WNB, that has been a WOW factor feature as well.
The new CAT/DAX (ver 1.5?) was very close to a WOW factor feature but in reality it falls more into smooth operation improvements. CAT and DAX were becoming cumbersome and it was the logical step forward.
The distinctive aspect of a 6000 is the VISUAL aspect. We get the most amazing panadapter display from any radio manufacture. I have tried many SDR software programs and no one come close to the quality of SmartSDR.... but, feature wise? Well, that is where it falls short. We have not had any new features added to the Panadapter. All that real state and no new things.
Markers, use of different colors, cluster integration, tagging, labels, customization, signal detection, CW, PSK, RTTY decoding, recording and playback of streams, there are just so many things that can be done in that space..... How cool would it be if the radio could suggest mode based on the info it gets from the panadapter. You put the slice on top of a signal, and you get a popup suggesting changing to CW based on the characteristics.
I want information, I want voltages, power levels, SWR numbers, and all kinds of neat things happening on my screen. I want some level of customization, I want to be able to organize things in certain ways and I want to be able to see, within all that real state if I have TX1 or TX2 enabled, if Binaural is ON or OFF, etc...
Common sense features are paramount, even though they might not be very sexy. Not having Squelch in my 6700 that is capable of monitoring 8 different frequencies is just plain wrong. And we know, thanks to FRStack, that it is not a difficult thing to add. But having to use FRStack to have squelch is not fun, is not appealing, it's just not the way I want to operate my Flex radio.
Profiles are very useful, so are memories, but we need to have a "better" profile manager. I want to be able to short, group and customized those Profiles. Maybe even be able to assign a few buttons somewhere in SmartSDR to be able to recall those most common profiles.
We have tons of room, heck, we can go 4k on SmartSDR, do you realize how amazing that is?? 4k of real state... nothing in ham radio comes close to that! And what do I get with 3840x2160 pixels?? A bunch of sub menus... come on. Who, here, is not using their Flex radios in the biggest monitor they can fit/afford? Only to realize that I have to click several times to go from LSB to AM, while I have a lot of space utilized by the DEXP slider which I set once and forget it. Same goes for AM carrier...
All of these things falls between "common sense" and "smooth operation". Those need to to be done inside version one... heck, I really think, and again, this is my personal opinion, that FRS needs to get those things right, and in V 1 of the software.
I would love to get Pre Distortion in my Flex... that falls in the WOW Factor category, but I would be disappointed if I get that before I get squelch.2 -
Steve, did you mean 2.0 or 1.x? On the "collaborative effort", huh?0
LOL, just have to buckle up and come on the ride. The 6000 is just getting started. All of what you said may or may not be done, but changes are certain going ahead. To me, the idea of such a clean state of the art software free of clutter appeals to me.
I did notice a few things mentioned about CW, PSK, RTTY decoding, these are taken care of in 3rd party software as it is intended to be.
As it is with any radio, everything you want in it may never happen, that's just how things are.
So, keep enjoying your high tech radio and grow with it as more things happen.0 -
Let me ask you Bill... and answer from the heart.... you wouldn't want to see some if not all the features I mentioned available in SmartSDR? Really? You do not want squelch, or band edge markers, or decoding inside SmartSDR?
So if Flex happens to add any of those... would you stay on the previous version because it is less cluttered? Furthermore, why would it be cluttered, did FDX, better CAT/DAX or WNB add clutter to SmartSDR when it was added?0 -
Ok wow. We know squelch is planned. Band edge would be nice. All decoding is taken care of with 3rd party software as it should be.
I just would like the screen to stay much as it is, clean. But I don't think I need to worry about that as it seems Flex thinks the same way. No I would not roll back if they cluttered it up more, I would accept the way it is and enjoy the radio.0 -
That is the point I wanted to make. From your perspective "as is" or any future updates will all be fine. Therefore, my comment is more about what some of us dream the SmartSDR could be... and for me, having those in the near future will make my flex ownership experience that much more satisfactory.0
I interpreted Bill's comments as more of a commentary that is easy for software UIs to devolve into a cluttered mess with every conceivable feature, control and capability crammed in which ends up interfering with the operating experience, not that he opposes any particular feature.
I am personally in agreement on this perspective, that it is easy to get carried away and make a perfectly functional GUI a pain to use and a cleaner, less cluttered interface is more ergonomic and functional to use. There are lots of examples. This is also a design prerogative of our GUI team to keep the UI highly functional and not distract from the primary set of use cases.0 -
And I suppose if we are comparing SSDR with other SDR software, what do we compare to. Remember PSDR went many years, 6 or 7 years before it had all the features it has. And some years later someone has taken it up again adding even more of late. The Anan folks are still working with it, changing it 10 years later.
So really, in the time SSDR has been out, It looks like it is moving along just fine.0 -
To answer Tim´s comment, and please, keep in mind that this is sharing different points of view and ideas so no one take offense.... I like these threads where anyone can freely share opinions.
If I have to have FRStack do squelch, CWSkimmer decode, CW Bridge interface CWSkimmer with SmartSDR, DXAtlas provide cluster and SmartSDR Setup opened to see binaural or TX1 enabled-disabled status.... how can I consider that screen uncluttered??1 -
That is one thing all us SDR folks deal with. The more apps you open, the more cluttered it looks. No wonder many use 2nd screens. But My comment is mostly about the normal operating GUI.0
ta dah...and that my friends is why it takes 3 mouse clicks to change band! Ergonomics and ease of use are being sacrificed for the sake of cosmetics.
Presentation over functionality is never going to work with such a complex eco-system with deep functions and menus etc.
It's only because so much of the essential functionality actually resides outside of SSDR in the likes of DDUTIl, CAT, DAX, FRStacks, Smeter etc. etc. that the interface can be kept to a minimalistic look.
Most of that "clutter" is still required in order to drive your station properly, so back comes the clutter. But, hey at least it not in the beauty queen SSDR right?0 -
For two SCU units in the Flex6700, would a Polar Mag/Angle Adjust Display so that Plasma TV
interference could be nulled out like on the ANAN200D or used in a Dual Beverage Vertical Antenna system arrangement to steer the beam to maximize a signal or null a signal electronically be a useful feature0 -
OK, I'll bite....in the spirit of dreaming about the future of features and improvements, not about complaining about what is missing....
Here are some things that I look forward to seeing released sometime during the V.2.x.x lifecycle...
V.2.0 ==
1) Full WAN remote without need for separate VPN for SSDR/Win, SSDR-IOS and Maestro.
2) Later - Multiple client capability - ability to connect with more than one client at the same time
V.2.x.x == the following are arranged by category, not by urgency.
Adaptive Pre-Distortion:
1) first for the rig itself
2) Then utilizing external sensors, add the ability to use it with external amplifiers.
GUI Improvements:
1) Variable layout - Let the user dock certain functions and menus to their favorite places on teh SSDR screen, or move them to a location outside the SSDR Window.
2) Improved metering/information output for multiple functions: S-Meter, Power Output, SWR, Input Voltage, mike/compression level, , etc Including movable, dockable readouts - analog or digital, with custom color choices
3) Custom colorization (to assist vision challenged operators),
4) Dockable sub-functions & menus (i.e. movable and customizable band, mode, filter, antenna panels, etc.)
5) Customizable filter bandwidth buttons, similar to PowerSDR, where three or four easy-access buttons could be programmed for each mode with custom bandwidth, hi/lo cut, and shape-factor/latency (like the newly release version).
6) Revisit changing some functions from mouse-sliders to click up/down buttons similar to those used for filter hi/lo control. Some functions need more precise control than a mouse can give. At minimum, allow hover-over use of mouse wheel to adjust them.
7) Programmable Band-edge Markers: thin custom colored lines, with user definable labels.
a) set by a right click, with optional text labeling. Color and width can be selectable. One single marker could even be set for an entire sub-band with custom color and transparency.
b) programmed by an editable list, similar to memories. Lists can be exported/imported as spreadsheet.
DSP Improvements:
1) Continue to improve ANF, NR, NB, WNB, APF, TNF, etc. Especially in need of work is the ANF.
2) Implement "Advanced User" or "Expert Mode" for many functions with easy "Reset to Default" to allow users to customize these functions as needed for their particular situations.
3) Mode-specific RX EQ settings - It should not require a major effort when changing from SSB to CW to shift the RX EQ from voice enhancement to CW enhancement and back. Options:
a) The RX EQ settings should either be remembered by mode,
b) Allow some form of "band stacking" where multiple presses of the RX EQ button
will cycle through two or three different settings.
c) Link the RX EQ to Mic Profiles and allow one of the profiles to be CW,
which is linked to CW mode.
AGC Improvements:
1) "Automatic Mode" for AGC-T that will automatically set the AGC-T to the optimum "Knee" or "Sweet Spot" depending upon band conditions and settings of Filtering and other DSP functions.
2) "Adjustable Active Hang ACG" that allows multiple time constants to be programmed for the AGC. Similar, but even more parameters than the Custom AGC in PowerSDR. (See details in another post) https://community.flexradio.com/flexradio/topics/active-hang-agc
Multi-mode Squelch Functions:
1) First, add a simple signal-level squelch for each slice.
2) Then later, Develop some sort of mode-enhanced squelch, such as a speech detection squelch that only opens in the presence of voice signals on ssb or AM. (a routine could detect the changing pitch of the spoken voice as an indicator that this is a voice, not a carrier or noise signal.)
Profiles:
1) Allow profiles to be sorted into subdirectories. i.e.
2) Mic profiles from different Mics could be put into separate directories to make selection easier.
3) Other profiles could be sorted by remote location, etc.
4) Global profiles could be divided into subdirectories for each operator of a modern station.
Audio Improvements:
1) Ability to record and playback multiple sound files from the receiver and the Mic.
2) Ability to export recordings to client computers in .WAV, MP3, or other formats.
3) Voice keyer - similar to CWX - internally stored and accessed by other clients like SSDR-IOS, Maestro, Dogpark, etc., or accessed with simple macro functions by logging programs.
4) ability to record, and/or stream to a computer the audio output that is sent to the speaker line - in stereo - in order to easily record contacts or contests.
Diversity:
I know that some of this is primarily a 6700 function....but other ideas are not.
1) Phase vectoring for electronic antenna steering
2) use phase and strength to implement enhanced diversity reception.
3) Ultimately, allow internet connection of rigs to create geographical diversity reception
4) Internet connected RDF capabilities via multiple receivers operating in conjunction with each other.
Outside Interfacing
1) Band-info accessible by the USB Ports
2) Ability to connect Flex-Control Knob directly to the Rig via the USB Port.
3) Ability to connect rotator controls directly to the USB Port (I am using a Yaesu G800DXA with ERC Controller)
Additional Digital Modes and Detection:
1) Add some additional digital voice modes beyond FDV and D-Star - there are several modes becoming popular on VHF/UHF. Some may already be encoded in the Thumbdrive unit.
2) Simple CW and RTTY decoding - sent to client in a window similar to the D-Star and FDV access window. Or sent to the client such as SSDR-ios so CW/RTTY could be read by a simple client without 3rd party software.
3) Simple RTTY Transmit capability, perhaps even with a CWX type interface
4) True FSK ability for those who want it. That may be part of the implementation of #3 above.
Test Equipment Modes:
1) Simple SWR Scanner -
2) VNA Mode - this equipment could be used as an excellent antenna analyzer to give an amazing amount of information about the antenna system, feedline performance, etc.
3) Audio Spectrum analyzer function - allow display of real-time or time-domain traces of the received audio spectrum. Individuals could vies a trace of their own actual receive filter performance, skirts, etc. or a more accurate analysis of their own or received station's audio profile/signature.
4) Built-in Two Tone and other functions for testing
5) built-in low-duty-cycle tuning tones for those who want an effective "wood-****" to tune their amplifiers. (I am not a particular fan of these, but I suppose they can be useful for some.)
Well...There are the best dreams I could come up with in the time available. I have lots more of them, because Dreaming is what I do.
Disclaimer: I am not employed by FRS. But I AM on the Alpha Team.
None of this post implies any dissatisfaction with the product as I have received it so far.
(except, perhaps, for Mode specific RX EQ (;>p) )
These are offered as forward-looking dreaming about the possibilities for this fine rig.
I do hope to see many of these enhancements released sometime during the next phase - V.2.x.x. - of SSDR development.
I have watched, and participated in its growth for over three years and have been very impressed. We've come a long way, baby! This is still the best rig on the market and it keeps getting better.
Ken - NM9P5
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 16 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
