Missing DAX Drivers After upgrade
Nick
Usual problems after upgrading to 1.9.7. Went in through Control Panel and deleted all Flex devices and drivers. Restarted machine and reinstalled package, got start up messaging saying error occurred while trying to open a DAX sound device. Lists three conditions, the first one is probably the problem, DAX driver not properly installed. Looking in Control Panel there is no devices listed for DAX. Reinstalled several times and no drivers installed. Any idea where I can download these drivers?
The reason you are having the "usual" problems is because of unnecessarily removing drivers that should not be removed.
Never manually uninstall the DAX drivers or the FlexVSP drivers unless you are explicitly instructed to do so. There is only one way to uninstall the DAX drivers correctly and that is by using the SmartSDR uninstaller or manually (which is referenced in Terry's post above)
This step is totally unnecessary for most software upgrades and will result in issues like this.
I have uninstalled literally thousands of versions of SmartSDR and I NEVER uninstall the DAX driver or FlexVSP. Never. Ever. I recommend everyone follow the same best practice for the most optimal new software installation experience.0 -
I totally agree on this as I removed everything as you did Nick and worked two days on problems. Dax and cat errors. The manual re-installs on both Dax and cat will resolve the errors if needed on one or both. 73's Joe WD5Y0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
