Ham Radio Deluxe & SmartSDR 1.8.4 Setup Help!
Thanks Larry for the info. Looks like there have been a few changes to HRD since these instructions were created.
When I select SmartSDR as my radio in HRD nothing works? The only thing that seems to get things working better is if I select “SDR-RADIO” from the drop down list in HRD?
Like,
Easy, just first you need to know that your SmartCAT (data from your 6000) and the DAX (Digital Audio eXchange) is working.. Look at your SmartCAT and determine your CAT port to connect to, usually Com4 or Com5 , but there will be a big blue square with a "C" (CAT Port) . This is your com port to be entered in the "Connect" window of HRD.. Set FlexRadio and SmartSDR , then click connect.. Just that easy, just for HRD..
For the audio in DM780 , make sure that the input audio (Capture as I remember) is set to your DAX RX Audio slice , usually channel 1, playback is the DAX TX audio channel.. (Besure to have the "DAX" button on in the TX Stack) And make sure that you have DAX audio "1" selected in the Slice window too under DAX..
That's it!
Hey Dudley I should mention that I had almost everything working when I was using the old 5.4 free version of HRD with my 6500. I have been using HRD for years so I am fairly familiar with the HRD setup. So I decided that it was time to update to the new paid version 6.3. to take advantage of some of the new features. But for some reason I can not seem to get everything to work together?
When I installed the new version of HRD 6.3 In the radio selection drop down list I selected (SmartSDR) then selected COM 4 for HRD and click connect and RigControl opens up shows the correct frequency and that’s it, it’s dead? Rig Control stays open but nothing works, No communication with radio? And If I select PowerSDR from the list in the new version same thing...Dead?
But... In the new version of HRD 6.3 there is a new option that says “SDR-RADIO” when I select that one it seems to get thing working. Rig Control now communicates with radio? So what radio should I select?
Now DM780... This is where I am having some trouble. The first thing I note is DM780 & RigControl are running sluggish and unresponsive.
I can get audio In & and out of DM780 OK but the PTT is where there seems be a problem. I created a dedicated (PTT) Port in SmartCAT as prescribed. And tried to get the PTT working but when I key the radio using a com port in CW Mode for example when I send code it will key the 6500 strangely. It will send characters in bursts then stop then start again and over and over again as if there is some kind of buffering issue?
I contacted HRD and the gentlemen I spoke with told me they don't have a Flex 6000 radio to test with HRD. It does not seem anyone there is all that familiar with the new 6000 Series/SmartSDR.
Soooo.... Is anyone using the latest version of HRD 6.3 and how do you have HRD & DM780 configured.
I'm running 6500, SmartSDR 1.8.4, WIN10 64bit, I7 Extreme, 32GB RAM, SSD HD's.
I have HRD 6.3 and it works OK with HRD logbook and DM780. I used the tutorial from DH2ID which is at:
https://community.flexradio.com/flexradio/topics/setting-up-ham-radio-deluxe-with-smartsdr-tutorial
I've been using HRD V6.x since it was introduced with no problems. You realize you don't have to use Rig Control, it's unnecessary and is a resource hog. DDUtil will handle the interfacing with HRD Rotator, DM780, and HRD Logbook. Just tick the HRD V6.2 button in DDUtil and start it before you open the HRD apps. I don't use DM780 for CW, just for the digital modes, but it works fine with a PTT set up on COM5, but I notice in the release notes for the latest HRD build, (6.3.0.563) that it's supposed to fix something CW related for Flex in Rig Control so if you feel you absolutely have to run that, make sure you have the release that came out this week.0
Yes running HRD build, (6.3.0.563).
instead of running the HRD main program to talk to Flex you can use DDUtil or the latest version of Mini Deluxe. Then only run HRD Logbook, DM780, rotor, etc.The main HRD program will run sluggish as others have stated.
There is a nice writeup for Mini Deluxe available here https://github.com/krisp/MiniDeluxe/wiki
Shut down HRD and all it's apps.
You will need to create two ports in SmartSDR CAT, a COM port and PTT port. I've created COM9 for CAT to Mini Deluxe and COM10 for PTT to be used by DM780. COM9 will follow slice A frequency.
Next download Mini Deluxe from the link above and run it. You can put a shortcut to it in your startup so it starts automatically with Windows. In the tool tray right click the Mini Deluxe icon (see picture) and select options. Select the CAT com port you created in SmartSDR CAT. Check the box for SmartSDR.
Now you should be able to run HRD Logbook and DM780 without starting HRD main program. They should connect to the radio correctly and show the frequency.
Last, DM780 PTT using CAT commands is a little slow in T/R turnaround time so I use com port PTT keying. Go into DM780 program options and select PTT. Select via PTT com port and select the PTT port you created in SmartSDR CAT. Check Set RTS and Set DTR.
You should be good to go.
Thanks Dave for the info.
Now that I have a 6500 I don’t need RigControl anymore and since I don’t have any special Amps or Rotors I decided to go with Mini Deluxe.I got it working with DM780 but I think I may have found a bug in HRD. It has to do with (CW KY Cmd) Mode. When I use this mode it locks up DM780 until I restart DM780?
I don't use that mode in DM780 but will test. See if there is something to change in settings.0
I would like to use this mode (CW KY Cmd) This will allow me to put the flex in CW mode and use DM780 for CW QSO with my keyboard. Basically this mode allows you operate the Flex’s CW the same manner as plugging a key into the radio. This allows you to still have control over Sidetone pitch, Level, Speed & delay from the Flex’s P/CW control panel. I was able to get this to work with the old version 5.2 of HRD.
I know I can use MCW mode but then I have to put the flex in SSB and then it moves the CW signal way off center and makes it a real pain in the but to use. Also with CW KY Cmd mode you also get full QSK Break in operation.I think there must be a problem with the CW KY Cmd mode in the latest version of HRD because it locks up DM780?
John
Also take a look at the setting in the (Modes-ID's) tab that is specific to CW Modes. There is an additional option for keying the Flex.
Not sure what it would take to get going but Flex SmartSDR CAT supports creating a WinKeyer port. Maybe use CW Winkey? Again I do not use DM780 for CW so I do not know what the settings should be.0
HRD interface with SmartSDR Winkeyer emulator is problematic at best. I found using the Winkeyer USB hardware between my Flex 6300 and HRD (latest version) in CW Winkey mode works perfectly.0
I am going to try to get the Winkeyer mode to work, like David said SSDR and HRD support this mode and because all of the data connections are through SmartCAT com’s "should" work great!
If i can not get that to work I will go with the Hardware option.
Well they both support WinKeyer but HRD supports WinKeyer 2 and Flex supports WinKeyer 3.
I've never tried it, post your results so others can benefit.
GOOD NEWS!!!
OK so in the end I decided to use MiniDeluxe because the current version of RigControl is sluggish and buggy and also why do I need another radio interface when SmartSDR does it all. I just want to use the other HRD programs anyway.So now I have created a Winkeyer port in SmartCAT and assigned to CWWinkey mode in DM780 and WOW it works great! Full break in and unbelievably fast the 6500 keying circuit is amazing. Holy Cow man the Flex is fast!
So just what I was looking for a fully software based keyer. I was just going to go with a USB to Keying adapter and plug into the key jack on the front but who need more wires in there shack. Besides it leaves the key port on the front free for my key or paddle.
Thank you everyone for the help
John
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
