Cannot Remove FlexVSPInstaller_64
W5UN_Dave
I have just upgraded to Windows 10 and am trying to follow the SmartSDR v1.7.3 uninstall procedure. I see FlexVSPInstaller_64.msi, but I cannot uninstall it. When I try I receive the message "this feature is on a network resource that is unavailable" Huh! How do I handle this? Reinstalling SmartSDR 1.7.3 will not me to choose CAT ports, is this blocking it?
Have you rebooted your computer before trying to uninstall FlexVSP.
Make sure you have backed up your profiles. Then do a complete uninstall 1.7.3 . Then you can try opening Task Manager and ending the task ftvspksrv.exe then see if you can uninstall.
Bill0 -
That is good advice. I always reboot befor and after any uninstall or install to make sure I am as clean as possible .0
all these things have been done, to no avail
Have you installed a later version of SmartSDR?0
I will try the 1.8 now
I had the exact same message on windows 10 when I tried an uninstall. I had to deviate from the uninstall procedure and uninstall FlexVSP first then smartsdr.
To do that after an unsuccessful uninstall, reinstall 1.7 , reboot and then uninstall VSP first then smartsdr and it worked for me and I have done so about 5 times0 -
Installing 1.8 DID NOT solve the problem. I'm afraid I will need to do a complete reinstall of windows 7, then up grade to windows 10 again
I've tried that. IflexVSPinstaller_64 is there, but cannot be accessed, no matter what I do. Any subsequent SmartSDR install will not let me add CAT ports
You might try downloading Revo Unistaller and doing a forced uninstall, followed by an advanced scan for leftovers.
You may want to consider a Win10 reset http://www.laptopmag.com/articles/reset-windows-10-pc0
I am not certain you have identified the correct root cause of your issue. I would recommend opening a HelpDesk ticket before taking more drastic measures.0
Dave,
I have had this problem a few times. The answer for me is to first locate the path to the FlexVSP installer file.
In the box where you receive the "network resource unavaliable" go to the browse box and point it to the path you located for the FlexVSP installer file.
This has worked for me.0 -
I submitted a ticket, as all else has failed
I had a similar problem, and my solution was to uninstall the VSP, by going into the folder ProgramFilesSmartSDR64-bit driversVSP. Then right click on FlexVSPInstaller_64.msi and select uninstall. Next I went into the windows device manager and deleted all Flex Com Ports as described elsewhere on this forum, followed by uninstalling SmartSDR. Reboot, and then do a fresh install of SmartSDR. Now I have all my Com ports back.
73 Peter G3ZSS0 -
Due to upgrade issues related to Win10, this issue fixed by a reinstall of the previous OS.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 721 Genius Products
- 387 Power Genius XL Amplifier
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
