flex 6500 recording
elan
elan Member
i do not own yet the 6500  however i like to ask a question since there is no way to do recording /play like the PSDR , however is there any way to do long recording if  i connect to one of the usb port  on the back memory stick ? this will be great thank you
vy 73 elan
  • Tim - W4TME
    edited March 2017
    Record off the air and Playback over the air is a current feature of SmartSDR.  To do long recordings you want to keep on separate media, use DAX and install wave file recorder software to store the file.  Then copy it off in whatever file format you want.
  • elan
    elan Member
    edited February 2018
    hello Tim
    thank you kind for the info  interesting info . but is it not a hardware upgrade for the feature?
    thank you for your time and support
    73 elan
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    Elam, I record all the time using Audacity. You can also record from your Mike and make voice keyer files to use in contest programs or use K9DUR's Voice Keyer program.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited July 2016
    I don't believe, however, SmarSDR has the feature of making IQ recordings. I really enjoy "tapinig" a band during the night and listening to it while I drive to work or take long walks.
    Jim, K6QE
  • elan
    elan Member
    ok thank you Ken and Jim
    73 elan g0uut
