flex 6500 recording
elan
i do not own yet the 6500 however i like to ask a question since there is no way to do recording /play like the PSDR , however is there any way to do long recording if i connect to one of the usb port on the back memory stick ? this will be great thank you
vy 73 elan
vy 73 elan
Record off the air and Playback over the air is a current feature of SmartSDR. To do long recordings you want to keep on separate media, use DAX and install wave file recorder software to store the file. Then copy it off in whatever file format you want.0
hello Tim
thank you kind for the info interesting info . but is it not a hardware upgrade for the feature?
thank you for your time and support
73 elan0 -
Elam, I record all the time using Audacity. You can also record from your Mike and make voice keyer files to use in contest programs or use K9DUR's Voice Keyer program.2
I don't believe, however, SmarSDR has the feature of making IQ recordings. I really enjoy "tapinig" a band during the night and listening to it while I drive to work or take long walks.
Jim, K6QE
ok thank you Ken and Jim
73 elan g0uut0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 720 Genius Products
- 387 Power Genius XL Amplifier
- 249 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
