Every time I start SmartSDR the aux. buttons on my Flexcontrol have lost the previous configuration.
Stewart, GM0GTU
Am I missing something?
Thanks, that worked. DE W6IW
???0
What worked?
Has no one else had this problem?
It's annoying to have to configure the Aux. buttons every time I start SSDR. I thought that it was supposed to remember all previous settings?
Try saving your correct setting in a transmit profile.0
Thanks for your reply Larry. Unfortunately that didn't work. It remembers all the other setting, e.g. mode, and filters.0
These parameters are saved in the local (as on the PC) SmartSDR settings file. If they are not being remembered, then that file is corrupted or there is a permissions issue on your PC that is preventing it from being saved.
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
