Every time I start SmartSDR the aux. buttons on my Flexcontrol have lost the previous configuration.
Stewart, GM0GTU
Am I missing something?
Thanks, that worked. DE W6IW
???0
What worked?
Has no one else had this problem?
It's annoying to have to configure the Aux. buttons every time I start SSDR. I thought that it was supposed to remember all previous settings?
Try saving your correct setting in a transmit profile.0
Thanks for your reply Larry. Unfortunately that didn't work. It remembers all the other setting, e.g. mode, and filters.0
These parameters are saved in the local (as on the PC) SmartSDR settings file. If they are not being remembered, then that file is corrupted or there is a permissions issue on your PC that is preventing it from being saved.
I have changed this post to a problem topic and converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
