6500 or Smart SDR freeze
Don't know who told you this is a "known problem with the new software" as the new software isn't really that new. It may have been seen before, but it isn't inherent in the software or hardware. I've definitely not seen it, but I also have only had my 6500 for a month or so now.
That being said, I can see how that could be annoying. How are you connected to the rig? Direct network connection? A switch? Wireless to a router which is connected to the rig? A hiccup in a wireless connection or through a switch may cause your issue.
A bit more info would be useful in troubleshooting, but again, I don't think it is inherent in the software (as your "this is a known problem" implies).
I also was experiencing freeze ups with the latest version of SmartSDR on a F6500. I did solve the problem by deinstalling SmartSDR completely after saving the Profiles. Only thing I did not erase was the master Profile file. Did the re-install. SmartSDR ran for 10 connectives days without a freeze or any other faults. As with most PCs and the Windows OS. Updating SW sometimes leaves artifacts behind that can cause problems. So sometimes the prudent thing to do is delete the SW and re-install. Never had to do that on my MAC computers. I have been using Macs and PCs since the 80's equally and find the Unix based SW to be the best. I don't use Linux as I feel the GUI is not as good as OS X. Any way just my 2 cents.0
Mike,
Just to be sure, was it the radio or the computer that froze up??
This weekend I took the 6500, laptop and Maestro to Field Day for a demo, which went well. However the laptop got hot (it's Florida) and froze. At first I thought it was the radio. But I fired up the Maestro and connected fine, without booting the radio. It was just the laptop, that was getting hot and freezing up! The radio never froze, and it was miserably hot out there!
W8XG Brent
Mike - this is a known issue with SmartSDR v1.7.x which has been addressed with the next release of SmartSDR for Windows (1.8)0
The radio is connected directly to my desk top. No switches, wifi or anything else. I can try a delete and reinstall of Smart SDR. The computer worked fine but the radio/Smart SDR was froze. Not sure what the buzzy tone was but that was a signal when the radio froze. I have an i7 4790k with 8Gb and a graphics card with 2Gb on it so the computer should not be the problem. Never has in the past in any event. I've been using the flex since last Nov.0
and there is my answer....do you know when 1.8 will be released?0
Soon1
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
