Audio amplifier for rear jack on 6500 ?
WK2Y
WK2Y Member ✭✭
edited October 2018 in FLEX-6000 Signature Series
I just got my 6500.  I have in the shack an SP30H non-amplified speaker from Palstar.  I would love to hook it up to the Flex.   There are tons of inexpensive audio amps out on Ebay.  For example,
http://www.ebay.com/itm/Lepai-Lepy-LP-2020A-Tripath-Class-D-Hi-Fi-Audio-Amplifier-w-Power-Supply-/19...  or
http://www.ebay.com/itm/Kinter-MA180-12V-MINI-Power-Car-Computer-Amplifier-USB-Port-Charging-Red-New...
Has anyone tried any of these amplifiers and found one that works well  and is not susceptible to RFI?
Thanks in advance for your help.
Bob
WK2Y
  • Walt
    Walt Member ✭✭
    edited October 2017
    I have the little Lepai that's been feeding audio to my twin speakers 24/7 for over two years now.  No RFI, BUT - I do not have tuners in the shack.  I have a remote tuner, with chokes both at the antenna and inside the shack, and I do not run 2 KW, so I cannot testify to high power and some antenna feedline with 8:1 SWR coming into the shack,
    But the little amp has worked for me.
    Cheers
  • WK2Y
    WK2Y Member ✭✭
    edited June 2016
    Thanks, I appreciate the feedback.
    Bob
  • M1tanker64
    M1tanker64 Member
    edited October 2017
    Bob,
    I use a Yamaha mixer/preamp, since I already had it, and output to  powered speaker,  http://www.sweetwater.com/store/detail/Rokit5G3,  a KRK Rockit5.  Although more expensive,  it has been a fabulous system and the powered speaker is shielded.  I bought the Rockit 5 from a pawn shop for about $80.00.
    Bob Hawkins, KD5AT
  • KM6CQ - Dan
    KM6CQ - Dan Member ✭✭
    edited October 2018
    I have been using the Lepai since I purchased the F3000, I have been using it on the 6500 for a couple of years now and with the KX3. It works very well. The power supply that came with it produced some noise, so I gave it the 9 lbs mallet rehab treatment before I threw it away. Insuring that it would never again become a violator. I run window line into shack and use a tuner. Oh, I have the same speaker you are using.
    73,   Dan
  • WK2Y
    WK2Y Member ✭✭
    edited June 2016
    Good to know.  My intention was to run it off of the power supply and not the wart so no worries from that perspective.
    Thanks and 73
    Bob
    WK2Y
  • WK2Y
    WK2Y Member ✭✭
    edited June 2016
    Thanks.  That speaker looks nice.Don't see to many shielded ones but maybe I need to use the phrase studio monitor.  Certainly looks better than a lot of the West Mountain and MFJ options.
    Bob
    WK2Y
  • Bill  /  VA3QB
    Bill / VA3QB Member ✭✭
    edited October 2017
    Bob
    I use COMspkr's from West Mountain Radio  $39  . They work great and no RFI.
    http://www.westmountainradio.com/product_info.php?products_id=com_spkr
    Bill Reid
    VA3QB
  • WK2Y
    WK2Y Member ✭✭
    edited June 2016
    Thanks.  Looks like it would be a good alternative if I hadn't alread spent the money on the SP30 H.
