Audio amplifier for rear jack on 6500 ?
WK2Y
I just got my 6500. I have in the shack an SP30H non-amplified speaker from Palstar. I would love to hook it up to the Flex. There are tons of inexpensive audio amps out on Ebay. For example,
http://www.ebay.com/itm/Lepai-Lepy-LP-2020A-Tripath-Class-D-Hi-Fi-Audio-Amplifier-w-Power-Supply-/19... or
http://www.ebay.com/itm/Kinter-MA180-12V-MINI-Power-Car-Computer-Amplifier-USB-Port-Charging-Red-New...
Has anyone tried any of these amplifiers and found one that works well and is not susceptible to RFI?
Thanks in advance for your help.
Bob
WK2Y
Bob
WK2Y
I have the little Lepai that's been feeding audio to my twin speakers 24/7 for over two years now. No RFI, BUT - I do not have tuners in the shack. I have a remote tuner, with chokes both at the antenna and inside the shack, and I do not run 2 KW, so I cannot testify to high power and some antenna feedline with 8:1 SWR coming into the shack,
But the little amp has worked for me.
Cheers
Thanks, I appreciate the feedback.
Bob0 -
Bob,
I use a Yamaha mixer/preamp, since I already had it, and output to powered speaker, http://www.sweetwater.com/store/detail/Rokit5G3, a KRK Rockit5. Although more expensive, it has been a fabulous system and the powered speaker is shielded. I bought the Rockit 5 from a pawn shop for about $80.00.
Bob Hawkins, KD5AT
I have been using the Lepai since I purchased the F3000, I have been using it on the 6500 for a couple of years now and with the KX3. It works very well. The power supply that came with it produced some noise, so I gave it the 9 lbs mallet rehab treatment before I threw it away. Insuring that it would never again become a violator. I run window line into shack and use a tuner. Oh, I have the same speaker you are using.
73, Dan
Good to know. My intention was to run it off of the power supply and not the wart so no worries from that perspective.
Thanks and 73
Bob
WK2Y0 -
Thanks. That speaker looks nice.Don't see to many shielded ones but maybe I need to use the phrase studio monitor. Certainly looks better than a lot of the West Mountain and MFJ options.
Bob
WK2Y0 -
Bob
I use COMspkr's from West Mountain Radio $39 . They work great and no RFI.
http://www.westmountainradio.com/product_info.php?products_id=com_spkr
Bill Reid
VA3QB0 -
Thanks. Looks like it would be a good alternative if I hadn't alread spent the money on the SP30 H.0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
