Has anyone needed to tweak their Tx equalizations for Maestro?
Roy Laufer
I took a little time out to adjust my Tx equalizations for the microphones that I usually use, and I was wondering how many people found the need to tweak any curves for use with their Maestro.
(I didn't ask if anyone had, since I am sure that a few have different tweaks just for the differing relative humidity in their shacks <grin>!)
Hi Roy
Using the hand microphone with the Maestro I needed to make adjustments.
Certainly is mostly making up for the hand microphones different characteristics and limitations.
I saved each configuration as a separate profile.
Steve
K9ZW
Yes MUCH different then the defaults for the hand mic, I also save a couple different profiles for normal and DX for the Maestro.
Yes I've tweaked the EQ and created a MIC Profile for an old LogiTech headset I got for skyping a couple of laptops ago. Plugs into MIC2 and phones, lightweight, hears good and sounds better than a hand mic from a few sound checks I've done. Have Bluearrott B250XT Bluetooth headset waiting in the wings for when Flex gets bluetooth enabled.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
