Has anyone needed to tweak their Tx equalizations for Maestro?
Roy Laufer
Roy Laufer Member ✭✭
edited June 2020 in Maestro
I took a little time out to adjust my Tx equalizations for the microphones that I usually use, and I was wondering how many people found the need to tweak any curves for use with their Maestro.
(I didn't ask if anyone had, since I am sure that a few have different tweaks just for the differing relative humidity in their shacks <grin>!)
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited March 2017
    Hi Roy
    Using the hand microphone with the Maestro I needed to make adjustments.
    Certainly is mostly making up for the hand microphones different characteristics and limitations.
    I saved each configuration as a separate profile.
    Steve
    K9ZW
  • WX7Y
    WX7Y Member ✭✭✭✭
    Yes MUCH different then the defaults for the hand mic, I also save a couple different profiles for normal and DX for the Maestro.
  • Mike VE3CKO
    Mike VE3CKO Member ✭✭✭
    edited April 2019
    Yes I've tweaked the EQ and created a MIC Profile for an old LogiTech headset I got for skyping a couple of laptops ago. Plugs into MIC2 and phones, lightweight, hears good and sounds better than a hand mic from a few sound checks I've done.  Have Bluearrott B250XT Bluetooth headset waiting in the wings for when Flex gets bluetooth enabled.
