Sensitivity on one slice depends on which band oposite slice is on
Top Dawg
I am running SSDR v1.7.30 on a Flex 6300.
I just thought we were going through a bad period in the current sunspot cycle. No matter which band I chose, there were either no signals or very few, especially weak CW. This has been going on for at least a month. Then today, I had slice A tuned to 20M and B on 15 and decided to try tuning B to other bands and lo and behold, when I put B on 40M, both slices began acting normally, i.e. there was activity on both, (I'm guessing about 15-20 dB increase i signal strength)
I've also noticed a great change in waterfall sensitivity on one slice when changing bands with the opposite slice which may or not be related.
This problem didn't show up till I updated to v1.7.30
Documenting this would be a pain since I would have to do screenshots of every instance, but I will if needed.
Not sure if this is the same problem. When I put up two slices, only one slice has good sensitivity.....the slice that I operated on most recently. If I retune on the new slice, sensitivity is normal on the new slice. I believe this normal.0
I dunno, but I would think both slices should have normal sensitivity.
Is the internal ATU operating? Tuner memory may be a factor.
Take note that the preamp gain doesn't change when changing slices if it is not desired. I suspect one slice sets the preamp gain to a new value and you are experiencing the result.1
Thanks for putting me on the right track Dan. Pp 91-95 in the SmartSDR User's Guide explains this in a little more detail but doesn't make clear why one slice/band should affect the other slice/band. In any event, it was the preamp gain being affected and all I needed to do was to turn the preamp on and Presto - I'm back on 20 CW!
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
