Sensitivity on one slice depends on which band oposite slice is on
Top Dawg
Top Dawg Member ✭✭
edited September 2019 in SmartSDR for Windows
I am running SSDR v1.7.30 on a Flex 6300.
I just thought we were going through a bad period in the current sunspot cycle. No matter which band I chose, there were either no signals or very few, especially weak CW. This has been going on for at least a month. Then today, I had slice A tuned to 20M and B on 15 and decided to try tuning B to other bands and lo and behold, when I put B on 40M, both slices began acting normally, i.e. there was activity on both, (I'm guessing about 15-20 dB increase i signal strength)
I've also noticed a great change in waterfall sensitivity on one slice when changing bands with the opposite slice which may or not be related.
This problem didn't show up till I updated to v1.7.30
Documenting this would be a pain since I would have to do screenshots of every instance, but I will if needed.
  • K2CM
    K2CM Member ✭✭
    Not sure if this is the same problem. When I put up two slices, only one slice has good sensitivity.....the slice that I operated on most recently. If I retune on the new slice, sensitivity is normal on the new slice. I believe this normal.
  • Top Dawg
    Top Dawg Member ✭✭
    edited June 2016
    I dunno, but I would think both slices should have normal sensitivity.
  • George KF2T
    George KF2T Member ✭✭✭
    edited February 2019
    Is the internal ATU operating? Tuner memory may be a factor.
  • W7NGA
    W7NGA Member ✭✭✭
    edited January 2018
    Take note that the preamp gain doesn't change when changing slices if it is not desired. I suspect one slice sets the preamp gain to a new value and you are experiencing the result.
  • Top Dawg
    Top Dawg Member ✭✭
    edited June 2016
    Thanks for putting me on the right track Dan. Pp 91-95 in the SmartSDR User's Guide explains this in a little more detail but doesn't make clear why one slice/band should affect the other slice/band.  In any event, it was the preamp gain being affected and all I needed to do was to turn the preamp on and Presto - I'm back on 20 CW!
