Maestro not seeing radio
kr4k
Maestro set up and "connected" to my WiFi LAN. There is only one subnet. My laptop running SmartSDR 1.7.30 sees the 6700, and the K6TU on my iPad sees the 6700. However, the Maestro does not show a radio in the "Select Radio" windows.
Can you check your router and be sure that it has been allocated an I/P address?0
Make sure you are not running SDR on your PC. Jim ka7gzr0
Make sure your wifi isn't doing client isolation.0
Maestro will still see the radio, just like with SmartSDR, but you won't be able to connect in this situation.0
Gus, if you're able to make it work with wired, you can look in the Network menu by pressing MENU and then Network and it will have some info about the wireless MAC/IP/etc that might be useful in diagnosis.0
Figure shows when wired and wireless connected. Works fine.
Figure shows immediately after pulling wired network.
Figure shows a few seconds later:
From Vigor 2925 router DHCP table showing Maestro
7 192.168.13.16 00-1C-2D-03-00-D6 23:42:30 Maestro
19 192.168.13.28 90-59-AF-56-6E-5C 19:58:04
24 192.168.13.33 88-12-4E-15-D4-E7 23:39:51 Maestro
There is only one subnet, and all other WiFi LAN devices working properly. Connected to radio just fine using Win10 running in Parallels on MacBookPro via WiFi, and K6TU working properly on iPad via WiFi.
Thoughts?
73/gus0 -
try restarting your 6300 with the maestro radio chooser window open.. see if it pops up...
1. Held power button down several seconds until I got the Win10 "slide down to power off". Powered back on and the everything connected to radio and worked fine.
2. When I do a short button power down where I see "Please Wait" on the screen, and a power back up, Maestro fails to see the radio, but shows WiFi connected as before.
3. When I did the several seconds button down power off again, and a full restart, I was able to connect to the radio again.
So my WiFi connection appears to have something to do with the Maestro power up. Will continue trying combinations and document with photos.
73/gus0 -
We had some weird connection stuff like that during one of the early alphas but haven't seen this behavior. glad your connected!
As Chris said, we had seen some weird and very unique connections like yours. Not many, but a couple. If you can recreate the problem each and every time, let the support team know. I can attest to the fact that the Flex coding team was amazing at solving some very weird problems. Glad you are online. Mine has been solid on the VPN tunnel (the one that Chris documented).0
The problem continues. Four times I have the exact same symptoms. In all four cases, my laptop (WiFi), my K6TU iPad (WiFi), and my wired desktop see the 6700.
Router: DrayTek Vigor2925, router shows Maestro and Flex in DHCP table, only one subnet
WAP: Apple Airport Extreme
Number of WiFi connected devices: 11
All devices on WAN working as expected.
Tried the hard Maestro reboot 5 times this morning. To get Maestro to see it, I had to reboot the 6700. Rebooted radio leaving Maestro in Select Radio Window - it worked.
Once rebooted, performance is as expected.
73/gus0 -
HELP! Trying out a new (pre-owned) Flex6700 - works fine with a PC - I have the Maestro (just received today -also used) and it won't see the Flex. It just sits there with no radio populating it. Tried rebooting to no avail.
this is a direct connection from the Maestro to the radio - no LAN
Will it work if you have the radio and the Maestro on a router with a DHCP server? Are you able to test that? mike va3mw0
haven't tried yet - that was the next plan ... however I'd still like to know why it isn't seeing the radio when connected direct. Note I connected to the Wifi - not sure if that then only looks for radios over Wifi ... the only network symbol that showed before I connected via WiFI had the little red X by it and said no networks available...
Many have better results with a router between the computer and the radio.0
Nothing worked - router, switch, direct... finally I did a reset of the Maestro and that did it. WHY I had to do a reset is beyond me. Reminds me a bit of the Flex5000 days ... anyway for now its up and running ... I'm A/B testing to my FTdx5000 in receive.0
The problem reported is not the same as the original post as the noted fix did not solve the problem Please reference the new conversation here: Cannot get my 6700 to connect0
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
