Flex control
Trevor-EI2GLB
Hi All id like to add some form of external vfo to my 6500 be it a Flex control or a dj console, one question is say in a contest environment when I spin the vfo with the screen focus on my logging program will it tune the flex, using the mouse wheel, I currently have to switch focus back to smart SDR and then scroll, it makes S&P very tiresome, Thanks Trevor EI2GLB
Try a Behringer controller, you'll find the free software for it here:
https://community.flexradio.com/flexradio/topics/behringer-cmd-micro-dj-midi-controller-for-use-with...
Alex - DH2ID
The FlexControl is locked to SSDR (or PSDR). That is one of major design features of it. The DJ Consoles are typically not locked so if you aren't focused on SSDR then they don't control it. I think there are a couple controllers that function the same as the Flex Control. I have found the Flex Control and VOX a great combination to allow you to use other programs while making contacts, tuning, or adjustment.0
You can use the Flex control regardless of where the focus is. Your next choice is the Maestro which will be released shortly.
The test teams are already contesting with it.
https://www.youtube.com/watch?v=1iOinuoMBHA
Mike va3mw
As above the Flex Control doesn't care what the focus is. In the meantime in the main Flexradio Control Panel you can set it so it automatically returns focus to whatever program you set it to so once you've stopped tuning it will wait the delay you set and return focus to your logging program.0
Ed W2RF the author of SDR-Bridge recently released an updated version which will allow up to 4 flex controls to control up to 4 slices. I have 2 flex controls controlling 2 slices which I can use to tune around in pileups and I can have a third slice open and by hitting the lock button on the slice I can listen to a fixed freq and it not be affected by any of the flex controls. This way I can have the fixed slice on the DX station and use the 2 slices, 2 knobs with 2 skimmers to independently troll the pileup. Different skimmers don't decode exactly the same pileup data so I can often see deeper into a pileup using 2 skimmers to determine where the DX is listening. The buttons on the flex control will allow the knob to control XIT RIT volume or AGC-T in the particular slice to which the knob is attached. All of this is focus independent of the logging software, or any other software which has computer focus.
I never tried any of the DJ surfaces because they take up too much desktop real estate but the SDR-Bridge/Flex control combo goes a long way toward SO2R functionality in my use. You can add 1 control and get a feel for it and if you like it then additional controls
73 W9OY0 -
??? I haven't used my DJ 2 LE or CMD PL1 midi controllers for a while, but I don't remember ever needing to keep focus on SSDR for them to work. The interface program must be running, but it only translates the midi commands to API commands and sends them to the rig via the TCP connection. It should run independent of focus. Even so, I still just use the FlexContrl Knob most of the time because it is just easier and takes up less space in the messy desktop. Ken - NM9P0
The behringer is a great add on t'ill Maestro is released.0
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 765 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 812 Third-Party Software
