Eq+settings+for+radiosport+headset+with+the+m350+element
Tony Hateley
I have just purchased a radiosport headset with a m350 element,could someone give me a starting point for equaliser settings.thanks
There is a preset in the radio for the M350 element for both normal and DX operation. Start with that and customize from there.1
HOWEVER ... Mike settings are so much dependent on YOUR VOICE that you might want to try Ken's Full Duplex approach to setting your mike as it gives results for your voice and hearing.
Thank you did not realise there was a setting in the menu,having a senior moment again. Lol.tony0
As Howard, the pre set mike settings may not work well for you voice, worth trying...0
- 391 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 309 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
