Eq+settings+for+radiosport+headset+with+the+m350+element
Tony Hateley
I have just purchased a radiosport headset with a m350 element,could someone give me a starting point for equaliser settings.thanks
There is a preset in the radio for the M350 element for both normal and DX operation. Start with that and customize from there.1
HOWEVER ... Mike settings are so much dependent on YOUR VOICE that you might want to try Ken's Full Duplex approach to setting your mike as it gives results for your voice and hearing.
Thank you did not realise there was a setting in the menu,having a senior moment again. Lol.tony0
As Howard, the pre set mike settings may not work well for you voice, worth trying...0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
