cat and dax problems after windows 10 update with ver 1.621
Mike Croce
Hi Guys
My Cat and Dax functions stopped working after i received a windows 10 update i uninstalled smart sdr ver 1.6.21 and reinstalled it like in the past but this time it did not work. any ideas? I own a flex 6500.
Thanks in advance
Mike N2PPI
Thanks in advance
Mike N2PPI
Go to your device manager to programs and features and be sure FlexVSP is installed.
Hi jim I have it installed. I also have the same problem with 2 other computers doing the same thing0
I had the same problem and cured it by COMPLETELY uninstalling FlexSDR a procedure which Tim has carefully written up. However, there might be better solutions from some one other than I as I only had that problem once.
Jim
On my Win 10 computer I need to install SSDR with Administrator privileges. In your download directory right click on the SSDR install file and Run as Administrator. Hope this helps.0
Thanks got my Dax to work but my cat still not working ...0
My CAT never works either, she just lays around the house.. hahaha.. sorry..
Mike, try this: https://helpdesk.flexradio.com/hc/en-us/articles/200883925-Removing-Hidden-or-Ghosted-Com-ports
Make sure there are no ghosted com ports.. then just reinstall SmartSDR CAT or should I say run the "repair" service on the FlexVSP.
https://helpdesk.flexradio.com/hc/en-us/articles/205665325-How-to-Repair-the-FlexVSP-Virtual-Serial-...0 -
Hi, I also have the same fault. Since windows 10 update SmartCat shows error on COM4. I checked the device settings and it shows two FlexRadio Virtual Serial Ports under 'other' I have followed all instructions as per this thread and still not working. Windows 7 still works fine.
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
