Another smooth install with SSDR 1.6.21
Gary L. Robinson
No problems, quirks, or nuclear melt downs with latest SmartSDR 1.6.21. Using Flex 6300 on Windows 10. Nice smooth uneventful install and everything seems to be running OK.
---Gary WB8ROL
---Gary WB8ROL
Did you Uninstall previous version? I assume...did you?0
No, I left the last version (1.6.17) on and did NOT uninstall it.
---Gary WB8ROL0 -
For clarity, uninstalling a previous version of SmartSDR is not required since each version install in its own unique folder. The issues arise if you uninstall a previous version of SmartSDR after you install a newer one, that can cause complications with shared components, particularly if you remove drivers.
Therefore if you desire to clean up and remove older version of SmartSDR, you should do it before you install a new version.0 -
Roger That!!
Thanks Tim!! Greetings from Venezuela
I will upgrade after finish my Jt65 contacts tonight
Cheers!
George
YV5WZ
Thanks Gary!!0
- 339 Community Topics
- 609 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
