Another smooth install with SSDR 1.6.21
Gary L. Robinson
No problems, quirks, or nuclear melt downs with latest SmartSDR 1.6.21. Using Flex 6300 on Windows 10. Nice smooth uneventful install and everything seems to be running OK.
---Gary WB8ROL
---Gary WB8ROL
Did you Uninstall previous version? I assume...did you?0
No, I left the last version (1.6.17) on and did NOT uninstall it.
---Gary WB8ROL0 -
For clarity, uninstalling a previous version of SmartSDR is not required since each version install in its own unique folder. The issues arise if you uninstall a previous version of SmartSDR after you install a newer one, that can cause complications with shared components, particularly if you remove drivers.
Therefore if you desire to clean up and remove older version of SmartSDR, you should do it before you install a new version.0 -
Roger That!!
Thanks Tim!! Greetings from Venezuela
I will upgrade after finish my Jt65 contacts tonight
Cheers!
George
YV5WZ
Thanks Gary!!0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
