Another smooth install with SSDR 1.6.21
No problems, quirks, or nuclear melt downs with latest SmartSDR 1.6.21.  Using Flex 6300 on Windows 10.  Nice smooth uneventful install and everything seems to be running OK.
---Gary WB8ROL
  • YV5WZ
    YV5WZ ✭✭
    edited December 2019
    Did you Uninstall previous version?  I assume...did you?
  • Gary L. Robinson
    edited February 2016
    No, I left the last version (1.6.17) on and did NOT uninstall it.
    ---Gary WB8ROL
    Tim - W4TME admin
    edited December 2016
    For clarity, uninstalling a previous version of SmartSDR is not required since each version install in its own unique folder.  The issues arise if you uninstall a previous version of SmartSDR after you install a newer one, that can cause complications with shared components, particularly if you remove drivers.
    Therefore if you desire to clean up and remove older version of SmartSDR, you should do it before you install a new version.
  • YV5WZ
    YV5WZ ✭✭
    Roger That!!
    Thanks Tim!!  Greetings from Venezuela
    I will upgrade after finish my Jt65 contacts tonight
    Cheers!
    George
    YV5WZ
  • YV5WZ
    YV5WZ ✭✭
    Thanks Gary!!
