SmartSDR v3.2.31 and the SmartSDR v3.2.31 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.5.23. | Power Genius XL Utility v2.2.10.
Will I be able to run my 6700 on a Maestro AND my PC at the same time?
When my Maestro arrives will I have to terminate SSDR on my PC while using my Maestro as the front end for my 6700, or will Maestro and my PC will be able to "play well together"?
[Hopefully, no one will offer the "this product is still in development and its final specifications have not been fully decided upon" card.]
Roy, AC2GS
My guess is with the current version of SmartSDR on the radio you will only be able to use one at a time. Until their add multi-user/device connectivity support. The Maestro is using an appliance version of Windows and is just like using your PC.
http://www.flexradio.com/amateur-products/flex-6000-signature-series/maestro/ ...Ready for remote operation with SmartSDR v2.0...1
From the same document:
Can I use the panadapters on both a PC and Maestro at the same time?
Not initially. This is currently planned for a future software release.
Will the purchase of the Maestro entitled you to a free upgrade to 2.0?
Can't wait to get mine.0 -
What I heard at Dayton was the later version would support using the Maestro as a control surface only when used in conjunction with a PC. In other words the system would not support Maestro and a PC simultaneously displaying slices, transmitting, etc.
In addition to the dials for tuning, etc, the Maestro screen would display some radio data and touch tiles but not the panadapter. It would be a mega-FlexControl with more buttons and dials. The nice thing about this strategy is that it does not involve the PC mouse --- So there are no issues with changing focus on the PC.
Of course, things could change but either way, I don't expect to see V2 for a while. Maybe mid 2016?
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com0 -
Initially you will have to decide if you want to run SmartSDR or Maestro for the control surface on the radio. Over time, more functionality will be added. Several options are being considered such as:
- Maestro controls SmartSDR and the display on Maestro shows "facts and figures" kind of data like which slices you are controlling, the frequency, etc. but not a panadapter and panafall display on the Maestro
- Maestro and SmartSDR show same data and work side-by-side
- Maestro and SmartSDR are "autonomous" devices that each control their own virtual radio. With this you could have two people operating what appears to be two radios at the same time. Of course, there is only one transmitter to be shared between the two positions
- Multiple Maestros connect to a single radio, each controlling their own "virtual radio" -- for contesters think of this as M/2 with two Maestros and a single radio
No decisions have been made about which of these we will do or when yet, but this gives you some insight into what we're thinking.0 -
If I use Maestro to run the Flex is there a way to send frequency and mode to the logging program on the desktop computer? All modern stand-alone radios have a CAT connection to a computer for logging. Would that be missing if I use Maestro?
73 de K1ESE
John0 -
Hi John,
Gerald Youngblood previously confirmed on this forum that logging programs (he specifically mentioned N1MM) running on a PC will work with SmartCAT over the LAN while the operator is simultaneously controlling his Flex transceiver with Maestro. DDUTil would work in the same manner.
FYI, you can also control any device supported with a serial interface by DDUtil (amps, tuners, rotator controllers) over the LAN by utilizing an Ethernet to Serial (RS232) adapter that connects the device (amp, tuner, rotator controller) directly to your LAN (router). DDUtil runs on the remote PC along with SmartCAT and connects to the Ethernet to Serial Adpater via a virtual serial port and special software that converts the control data to TCP/IP format and forwards it over the LAN to the target device through the Ethernet to Serial adapter. There is no need for a local PC at the station.
Larry KB1VFU
So this sounds like HRD and other control /!logging software will not work.0
Logging and control software will be fine -- today only one "GUI client" allowed at a time.0
It would be great to have maestro and smartsdr connected to the flex at the same time. Technically I don't see that being a big deal to implement1
You can run SmartSDR CAT and DAX on the PC for logging and digital modes without running SmartSDR. Then use the Maestro to control the Flex.
This frees up screen real estate on the PC.
For my operating preference the default would be option 2, Maestro and SmartSDR work side-by-side. Adding the other options over time works ok with me, but not being able to use the Maestro like a big brother FlexControl while I keep my nice big sized panadapter in the computer screen would be a step back. Mainly because my 6700 becomes a 6300 if used only with the Maestro if I cannot simultaneously see other slices besides the 2 available at the Maestro screen.0
Hi Salvador,
Same here on the option to use Maestro as a "a big brother FlexControl." From Steve's comment above:
I asked about this at Dayton 2015, and Steve also mentioned that additional controls (i.e. touch screen buttons) could be implemented as well. So Knobs and buttons.
I expect this to be the mode I would use 99% of the time. Since this is an enhancement that may not be offered for a long time, I decided to wait before ordering a Maestro.
Once I hear this option/mode is actually coming and an approximate time, I'll put in an order. Maybe 2017?
Regards, Al / NN4ZZ
6700 - HW.................... V 1.6.17.74
SSDR / DAX / CAT...... V 1.6.17.156
Win10
I would want to use Maestro not only for remote operation but as an add on at my station with the ability to use it and smartsdr at the same time. Otherwise I'm taking a step back from using my 32 inch display for my pan adapter. Even putting the ability to have and external display on the back of the Maestro acting as a mirror display would be fine. If this is something that is not going to be added via firmware, I'm going to cancel my order.
Without this ability its not worth the money and I'm sure many feel the same way.0 -
Is this something that is going to be changed via firmware or is this get what you see?0
The is a feature that will be added to the SmartSDR ecosystem of software in a future release.0
Okay, that's great news...0
It isn't trivial. When you can connect multiple GUI clients, the radio becomes multi-user capable and there are a lot of conditions that have to be handled to prevent multiple users from performing conflicting commands at the same time.0
That I understand but in my case there is only one user and thats me.0
So sending the GUI to 2 different devices at the same time is the tough part, but, will the Maestro still allow all the GUI control (knobs) plus whatever other data can be displayed in the screen minus panadapter while also having SmartSDR open?
So basicly, you select where the panadapter and waterfall info goes, PC or Maestro, but both can't be on at the same time. Right?
And eventually, in the not too distant future, we can have both PC and Maestro panadapter GUI at the same time.
The Maestro is still valid as a way to use the Radio without a computer (if you don't need to use an amp) or as a device to use the radio away from the radios shack (this can be done with a Laptop...) and definitely as the accessory to have if you are into contesting.
Personally, I am not cancelling my preorder, but I am analyzing the use scenarios in my case.
Having the Maestro and SmartSDR show same data and work side-by-side would be my preferred option too.
I agree, I want to be able to use both and I don't want to have to wait 3-4 years for the software that will enable this functionality. I'm not one to want to take the Maestro pool side, or into my living room and I don't do dxpeditions. I was wanting it to provide knobs to the radio while at my main station. If It doesn't allow me the use of SmartSDR on my PC, then I'm having a hard time figuring out what I would do with it. When traveling, I'm going to want to have a logging program and possibly digital modes. For this I'd be taking a laptop or tablet. Not sure why I'd want to also take the Maestro. Shoot, its big and I travel light, typically with just a carry-on bag. I guess I need to think this through a bit.
Is there something I'm missing here?
I don't think your missing anything and I agree with your statement. If what Tim said is true then that's great. But like you, I'm not willing to wait years or months for that matter. That's why I'm re-thinking about canceling my order.0
Me myself took something for granted in that the maestro would work in a mirroring setup to the monitor as well and not one or the other. Now with this limitation it's very hard for me to justify $1200 sitting around just for remote operation for any period of time.
For hams that must have knobs and are not Computer literate, this is perfect for them. For me on the other hand it's just spending money for something that's limited in use.
I sent a email to Matt Youngblood who I have been in contact with about shipping dates expressing my concerns about this as well. But have not heard back yet. I'm leaning towards canceling my order.0 -
Nick - we have been upfront about running Maestro and SmartSDR for Windows at the same time would not be in the initial release of SmartSDR for Maestro. It has been on the Maestro product web page FAQ since we first published it last summer.
Even Steve's official response above 6 months ago indicates that the initial release would not support dual operation with SmartSDR.
As with any new software / hardware integration project, we have to get the core functionality released first and make it solid before adding additional new features.
We have committed to adding this functionality in a future release of SmartSDR for Maestro.
However, if you still feel that canceling your order is the most appropriate course of action for you, we will dutifully accommodate your wishes.0 -
Remember the price at Dayton was discounted...
- so if you cancel now.. it will cost you $200 more to buy one later...
I wish that was the case, I did not get any discount.0
I understand, as long as this is in a timely manner and not a year from now. 0
What's the point of a single user server?
Howdy, Stranger!
- 16.2K All Categories
- 72 Community Topics
- 1.9K New Ideas
- 152 The Flea Market
- 5.5K Software
- 5K SmartSDR for Windows
- 45 SmartSDR for Maestro and M models
- 111 SmartSDR for Mac
- 151 SmartSDR for iOS
- 151 SmartSDR CAT
- 75 DAX
- 280 SmartSDR API
- 7.2K Radios and Accessories
- 5.9K FLEX-6000 Signature Series
- 573 Maestro
- 15 FlexControl
- 738 FLEX Series (Legacy) Radios
- 178 Power Genius Products
- 134 Power Genius XL Amplifier
- 15 Power Genius Utility
- 29 Tuner Genius
- 49 Shack Infrastructure
- 27 Networking
- 105 Remote Operation (SmartLink)
- 54 Contesting
- 157 Peripherals & Station Integration
- 64 Amateur Radio Interests
- 436 Third-Party Software
