Recieve Filter Direct Value Entry, Is this possible?
I wanted to know if it is possible to enter the receive filter upper and lower values directly using the numeric keys on my keyboard.
In the radio panel and in the slice flag you can hover the mouse over the filter edges to change filter settings but when I want to get exact values it is very hard to do with the mouse.
If this is not possible, It would be cool if when you double click on the filter a pop up box opens allowing you to enter the values direct.
John
John,
I don't think so... But it is possible to set the filers to exact number with a DDUtil macro..
AL, K0VM
It's so frustrating that such simple things like this are not just built in to SSDR.0
John
One work around might be, saving your custom filter as a memory.
I do that to get 0-4k filters for WSJTX.
The won't show up as selectable filters on the mode panels but they can be selected from SSDR's memory window whenever you want to use them. No 3rd party apps needed.
73, Jay - NO5J0 -
A bit over complicated for changing filters on the fly.
I hope simple features like this start show up in future version.0 -
I agree!1
The easiest way would be to set up a user customizable filter bank either under
settings or by right-clicking on the filters.
Alex - DH2ID1 -
Yes right click is what it should be. Maybe when you right click on the filters it could have options like "Edit Filter:, Copy Filter, Save Filter"?
So when you click "Edit Filter" you can manually enter the lower and upper filter values?
Just a thought.
John,KC2QMA
PLEASE CLICK "ME TOO" at the top of the post if you support this idea.1 -
Is it possible? Yes, as it is just a SMOP (simple matter of programming).
There is a filter widget for setting filter widths by doing a mouse over on the lubber (carrier) line at the bottom of the slice where it meets the panadapter. You can also dynamically drag the filter skirt edges to any point within the maximum bandwidth of the slice. None of our software has had a direct entry feature for adjusting filter widths because it is so much more convenient to do it visually by dragging the filter skirts, so we will have to evaluate the global usefulness of this request. Thanks for the idea.2 -
Visual mouse adjustment is convenient but can be frustrating for accurate. If you are trying to get to 1.0 it is quicker and more convenient to just entry the value. Using the mouse is a struggle to get it there and more often than not it ends up some value close but not dead on. Everyone has a different view and having the option to do both would good.
User configurable filter presets like the newer knob radios is highly desirable. It would even be nice if the presets automatically changed based on mode, like the Icom 8600/7700/7800 or Kenwood 590/990.0
Yes David, it's difficult to use the mouse when you want set the filter to exact values. And I would also be great if you could save your own filter presets.
Remember to click the ME TOO button at top of page.0 -
My ME TOO is to establish my own filter presets. All I basically want to do is replace all the 100hz low freq cutoffs at wider phone bandwidths with 50hz ;-)
73, Barry N1EU1 -
Yes custom filter presets! I have never owned a 5000 but doesn’t Power SDR already do this?
It sure does. That's all I'm asking for, customizable filters like in PSDR.1
Please click the LIKE or ME TOO buttons at the top of the page if you support this idea.
Sounds like a feature for some third party person to make an add on helper utility ... Lions and tigers and FlexLib oh my! :-)1
NO! Why not built IN?
Why should we need to use 3rd party software for simple features that can be a part of SSDR.0 -
For a current work-around you could use either of these:
1. macros with the SH and SL CAT commands to set the upper and lower filter limits.
SH Sets or reads VFO A DSP Filter High Cut Index
SL Sets or reads VFO A DSP Filter Low Cut Index
2. DDUtil DD6FIL macro
DD6FIL Set Slice, Mode and Filter parameters (rev'd @ 32300)Form: DD6FIL P1 P2 P3 P4 P5 P6 P7 ; Parm: P1 = Slice 0-7 {A-H} & 9 for active slice. Parm: P2 = Separator (:) Parm: P3 = Mode = 2 numerical digits {00=LSB, 01=USB, 02|03|04=CW, 05=FM, 06=AM, 07=DIGU, 09=DIGL, 10=SAM, 11=NFM, 12=DFM, 20=FDV, 30=RTTY, 40=DSTR} Parm: P4 = Separator (:) Parm: P5 = Filter Center = 4 numerical digits prefixed with either a ‘+’ or ‘-‘. Parm: P6 = Separator (:) Parm: P7 = Filter Width = 5 numerical digits for the filter width in Hz. Uses: DD6FIL0:01:+0000:02500; Note: Above example sets slice 0 to USB mode and sets the filter center point to 0 Hz and filter width to 2500 Hz. Use slice = 9 (DD6FIL9...) to set parameters for the active slice.
That is always an option but having apart of the SmartSDR GUI would be better for one place to manage the radio and not another add programming. There are few things could be tweaked in the GUI like making use of right click on the radio panel options like filters to bring up the level so you don't have chase down the slice. It would also be good if the panel fit vertically at least on 1080 resolution screen. It you use the horizontal listing at the top to rearrange the order would be useful too. Those are just few items that come to mind.
I thought this was the beauty of the panadaptor, drag the filters were ever we want?0
Yes dragging the filters are fine for quick approximate filter settings BUT... when you want exact values with the mouse it can be very difficult to achieve. Also we want to be able to save our filter presets for instant recall.
Yes Barry, I was aware of these alternatives but hope that this SIMPLE feature will be included in a future version of SSDR.
Well what ever, I'm sure they are aware of this thread. We will what happens in the future.0
Please click the LIKE & ME TOO buttons at the top of the page if you support this idea.
If you guys want to drool over one implementation of SDR filter customization, view this video at 3:58 in (choose HD 1080p in settings and watch full screen):
https://www.youtube.com/watch?v=iEZ2RjfQDKA
73, Barry N1EU2 -
Holy Cow! Now this is what I'm talking about! Amazing that it's only V3! Look at how much further along the GUI is compared to SSDR.
Fully customizable AGC with graphical feedback!
Audio Scope
S-meter with Peek reading.
All slider values shown all the time. (See what I mean Now!)
Customizable colors, skins and so on...
And so much More More More................
This GUI is light years ahead of SSDR.
I sure hope we don’t have to wait to till Ver.4,5,6 to see these items to show up in SSDR.
I almost fee embarrassed that I have to ask for such obvious features.
Now don't get me wrong the 6000 series radio hardware itself is amazing with it's networking, Build quality and so on but the GUI has a long way to go. PowerSDR already has many of these features today. You would think when you are coming out with a new product to replace an older one you would carryover all of the features from the prior software and then add the new features?
IMHO I don’t think FRS should be charging for software updates until SSDR has most of the features of Power SDR.
Most of those features for the GUI improvements / enhancements are on the idea list already. Some go back several years. There are about 800+ ideas so it take some time to find them all. Not many folks vote so it't hard to tell how important they really are.
FRS is making their decisions on where to put development resources where they feel it will provide the best ROI.
I expect we will see a few GUI improvements added at time goes on but it may take a few more years.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 - HW.................... V 1.6.17.74
SSDR / DAX / CAT...... V 1.6.17.156
Win10
The software in that linked video blows my mind, but there's no telling when it will actually be released for general use. The video shows Simon Brown (the developer) running early development version of the software on ANAN hardware. If/when it is released, it will be a game changer.
73, Barry N1EU1 -
Simon is a software genius he is why Ham Radio Deluxe even exists.0
I don't mind paying for software, as long as the vendor provides an up front feature specification/commitment so I know exactly what I'll eventually be getting.
Barry N1EU0 -
Yes Barry, I don't mind paying ether but I think since SSDR is so far behind PowerSDR maybe they could wait until they are closer to what PowerSDR has now before charging for the updates for SmartSDR?
Well at least this thread is "Under Consideration"1
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 766 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
