PTT and DVK not possible on split!
iz7auh
Hi,
with new realease is very impossible use frendly a DVK because... it is very difficult to use a DVK now in split mode , the issue that creates COM SmasrtCAT with ccess to a specific SLICE , so if it operates in SLIT does not work properly you have to change the SLICE reference this made it very difficult to use I hope you to recognize count of how many difficulties you have created in these and other situations , I consider it necessary an immediate release of other release , I think I return to whisker version 1.5 because it is impossible to work in a friendly and simple now
How are you putting the radio into split mode? What CAT commands are you sending to the radio to do this?0
Does your DVK assert PTT before playback starts? That could be the way to switch to the desired slice (Assign CAT PTT COMX port to the slice).
Ok Danny I try....0
Good examples of this PTT port assignment for a slice here
https://www.youtube.com/watch?v=uXM-kRLS1Rg
Illustrates digital modes in the video, but FLDIGI or DVK it uses the same principal.0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 331 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 779 Maestro
- 42 FlexControl
- 730 Genius Products
- 253 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
