PTT and DVK not possible on split!
iz7auh
Member ✭✭✭
Hi,
with new realease is very impossible use frendly a DVK because... it is very difficult to use a DVK now in split mode , the issue that creates COM SmasrtCAT with ccess to a specific SLICE , so if it operates in SLIT does not work properly you have to change the SLICE reference this made it very difficult to use I hope you to recognize count of how many difficulties you have created in these and other situations , I consider it necessary an immediate release of other release , I think I return to whisker version 1.5 because it is impossible to work in a friendly and simple now
How are you putting the radio into split mode? What CAT commands are you sending to the radio to do this?0
Does your DVK assert PTT before playback starts? That could be the way to switch to the desired slice (Assign CAT PTT COMX port to the slice).
Ok Danny I try....0
Good examples of this PTT port assignment for a slice here
https://www.youtube.com/watch?v=uXM-kRLS1Rg
Illustrates digital modes in the video, but FLDIGI or DVK it uses the same principal.0
- 713 The Flea Market
- 208 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 990 Genius Products
- 329 Shack Infrastructure
- 234 Networking
