I can't fill out the service request form
Bill-W9OL
I'm trying to fill out the service request form
even though I put in my sn 3413 0588 6500 5293
and
even though I enter the version number: v1.5.1.152
the system rejects my service request saying that both those two items are incorrect and it won't allow me to leave them blank.
I gave up after 3 tries making sure I had no typos.
and
Bill,
Try it one more with without the .152 in the version number. Jjust 1.5.1
AL, K0VM
Bill - you are missing the dashes in the serial number and there is a "v" in the version number. For each field there is an example of the format you should use to enter the data.
Also the serial number and software version number are not required to enter a HelpDesk ticket. Only the fields with the asterisk (*) are required.1 -
I tried it multiple ways, guess I didn't hit the right one. will give it another go0
The serial number on the back of my radio does NOT have dashes between the 4 groups of 4 numbers. That is why I tried it that way.
I removed the dashes and it has now gone through
Thanks for the help
RRR. It is shown in SmartSDR (Radio Setup->Setup tab) with dashes. That is why we selected that format. I'll see what I can do to modify the regex filter for the serial number field to accept spaces and dashes.1
I learned a little more on regex yesterday and it is now accepting spaces in the serial number field if one forgets to add dashes.0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 774 Maestro
- 42 FlexControl
- 729 Genius Products
- 253 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
