SmartSDR v3.3.32 and the SmartSDR v3.3.32 Release Notes | SmartSDR v2.7.6 and the SmartSDR v2.7.6 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
expert 0 F3K 4
John
I had an "expert" around today,in setting up the flex to run with other software such as wsjt and fldifi and after 4 hours, he walked away threatening to **** my f3k. I could not resist a "I told you so" quirk as he left with 4 beers in his belly to wash away his sorrow. Well, I am still using my trusty ft-897d to do all the digital modes for me. I wonder if he will ever speak to me again, let alone take up my new challange. Bed time calls.
I recommend you talk to the real experts, so I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.3
Strange setting my f3k for digital was a breeze.. The only problem I had what with different sampling rate between my virtual cable and what the radio was outputing distording my signal.. after working it out, I was able to decode anysignal I could come across that I had a software for..
Hi Tim,
I must apologise for incorrectly posting the article as I did not want any help. It was mouse and eye co-ordination problem when I ticked the wrong box. Well, I met this guy at one of our local radio stores and he said that he could help me set it up as long as I had a purchased copy of VAC which I have. the crux of the matter is that this whole issue of running virtual ports is not understood as there are many variables from computer to computer and I think many will agree that its a steep learning curve even for those "experts" out there.
As I have said before, I have long given up on setting it all up, so will continue to use my ft-897d with cat / data cable for digimodes.
John, I have had my f3k running here for some years and still use it as
a backup station for my f6.5k. If you have problems setting your f3k up
I could guide you step by step. You can also post some screenshots of
your setup here and look at the FRS knowledge center:
http://kc.flexradio.com/KnowledgebaseCategory96.aspx
VAC setup:
http://kc.flexradio.com/KnowledgebaseArticle50230.aspx
Setting up the virtual cables and COM ports is quite easy,
I recommend using VSPE, which is free for 32bit and has
to be licenced for 64bit.
73, Alex DH2ID0 -
Hi Alex, Thanks for the reply. I would like to try and set it up with your help but you will have to be a bit patient with me...medical problems included. I already have vac so would prefer to use that. Another purchase is not an option for me unfortunately.
Alex, I am in the process of having another go and in the vac control panel, I have two cable active. See image. F3K is set up in vac as wdm-ks vc1 input and vc2 output. I cannot get vc on MME or WDS
Wel, I think its working with a few hiccups. in order to set it up, I had to use vac software and this then forced me to use WDM-KS in the w3k audio set up menu. I could not find virtual ports in fldigi which corresponded to the VAC ports. Fldigi feezes when I try and change modes and has no tx. Faros software works ok.
Thats it for now, but its looking as if I have got over the worst.
Does anyone know how to set up a ptt port using vac software ? I cannot find the answer or I am looking right past it somewhere.
- 18.5K All Categories
- 132 Community Topics
- 2K New Ideas
- 279 The Flea Market
- 6.2K Software
- 5.4K SmartSDR for Windows
- 93 SmartSDR for Maestro and M models
- 211 SmartSDR for Mac
- 188 SmartSDR for iOS
- 180 SmartSDR CAT
- 113 DAX
- 321 SmartSDR API
- 7.8K Radios and Accessories
- 6.4K FLEX-6000 Signature Series
- 630 Maestro
- 29 FlexControl
- 777 FLEX Series (Legacy) Radios
- 408 Genius Products
- 240 Power Genius XL Amplifier
- 145 Tuner Genius XL
- 23 Antenna Genius
- 119 Shack Infrastructure
- 75 Networking
- 204 Remote Operation (SmartLink)
- 91 Contesting
- 306 Peripherals & Station Integration
- 87 Amateur Radio Interests
- 580 Third-Party Software
