Rev 1.5.1 and DXLab Commander Issue
Brad - N6SPM
After upgrade from 1.5 to 1.5.1, Commander won't connect to radio unless I change the config from Flex-6500 to Kenwood; when I do this everything is generally OK. Obviously, CAT and the ports are working fine but it now needs to be configured Kenwood instead of Flex-6500? Flex 6500 Windows 10 and latest DXLab suite.
Hi Brad,
There have been some issues since 1.5.0 with Commander not discovering the 6000 series radios when using the Ethernet API. The problem is not consistent and I don't think Dave, AA6YQ, has been able reproduce the problem reliably.
Try specifying your radio's IP address and IP port (4992 is the default) on Commander's radio configuration page. I did that and it has been working well with both 1.5.0 and 1.5.1.
Also, make sure your Commander is up to date as there have been a lot of changes lately. 11.9.3 is the current version.
73, Bob, N7ZO1 -
Thank you Bob - That worked. I have dynamic address assignment on my home network, so this may be necessary each time I fire up?
73, Brad, N6SPM
Hi Brad,
DHCP address assignments don't change that often on home networks. DHCP servers (usually your main router) have a lease period during which they reserve the address for that device. Most routers have a setting where the reservation can be made permanent, what is usually called a static lease.
So, no, you probably will not have to change the setting as long as the radio is fired up once in a while (every couple of weeks?).
73, Bob, N7ZO1 -
Is not necessary in the last version of the Commander care concerning radio IP - just skip it - don't fiil in, use radio serial number only, exploring broadcasting works well in last commander. BTW last commander has other issue with DAX channel( strange ? ) - always resetting DAX to channel 11
I had similar issue ,I deleted all of my com ports and opened ssdr and scat again, everything started working. Greg ni8r0
My commander is working perfect, no issue with SMART SDR 1.5.1
Jim
WU5E
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
