NO AUDIOI 1500. Software2.7.2 on i7 Win 7. Turned on Flex. drivers installed. Opened PowerSDR hit s
Carmine Mandarano
I have a 1500. Installed software on i7 computer. rebooted computer.Turned on Flex. Win 7 installed the drivers. Opened PowerSDR hit start NO Audio No signal on pan, after hitting start adapter just noise.All connections fine. Help??
hello,
try to uninstall and reinstall PowerSDR
you need to select your sound card info under the setup/audio tabs in the menu first
When I powered on the 1500 did not reinstall drivers I guess that's normal.Opened Powersdr opened setup/audio tab buffer size 2048 enabled vac1, nothing . Opened the Flex radio icon says no device connected. I can redo everything.0
Tried it Pat someone else said I had to select sound card. Only one is in computer here is my response: When I powered on the 1500 did not reinstall drivers I guess that's normal.Opened Powersdr opened setup/audio tab buffer size 2048 enabled vac1, nothing . Opened the Flex radio icon says no device connected. I can redo everything.0
why are you using VAC 1?
Someone said to go into audio and activate sound card so I tried it. I do not have a soundcard only what's in the computer A fast HP I7. Do I need a sound card?0
if you have no signal on PAN take a look to the antenna
Antenna works fine with my other rigs. I switch in the Flex with good coax switch0
the sound is not done in your computer, it is done in the radio, just plug in you power speakers to the audio out on the radio on the back
Using headphones no audio nor on display0
I would re install PSDR, this should all be working on start up with nothing to adjust .
Just did Bill Now computer did not install the drivers for the radio doing it again.
It seems with computers I defy Einsteins definition of insanity.0 -
take a look here : https://www.dropbox.com/s/its4q60hus68pai/Capture.PNG?dl=0
if you have that drivers are OK0 -
if you can try another computer
Did that too. Just tried the audio test nothing. Standard stereo headphone should be ok??0
this should be a very simple install, you don't need to think about drivers, they should be taken care of. un install everything you can, re boot computer then re-install, see how that goes
I think I will call Tech support in am. Are they helpful?0
yes they are the best, they will help you, first they will ask you to do what I just mentioned
make sure no anti virus or any scanning programs are running
Ohhhh! Mcafee is running. Will try Thanks Bill On other radio will let you know0
Hey Bill I have Sound. No Sginal but one small step at a time0
can you post a shot of your screen?
With antenna hooked up0
you have no signal on ssb on any band?
you do have the correct settings in antenna ie. pa receive and pa transmit and also check that you dont have a transverter selected instead !
He has the 1500, it does not have those options, it should just work with out anything done
No not on any band.0
I don't know,,think a call to Flex, and let the help you....Can you transmit? Mic connection? maybe the resceive is cut out?0
the views of manipulations and photo Desktop, I am afraid that the transceiver have a big problem.it happened suddenly? no storms or antenna SETTING?
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
