What's in profiles?
Martin AA6E
Martin AA6E Member ✭✭✭
I would like to understand exactly what data are stored in profiles, both Global and Transmit.  The Software User's Guide gives a nice table of what parameters are set by "Persistence", but only vague information about profiles.
One example: Where is the transmit bandpass info kept?  I need to switch this often when moving from JT65 to SSB operation, but so far haven't figured out whether I can do this with profiles.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited September 2015
    I think the question would be more easily answered on what is NOT
     stored in profiles. I have asked this same question, also.
    Jim, K6QE
  • Ian1
    Ian1 Member ✭✭
    edited May 2020
    Your question has been asked many times before.
    I would say do a search but with the new software release the items have changed.
    Example currently EQ settings are stored with older software version they weren't.
    Ian
  • Tim - W4TME
    edited March 2017
    I have entered this report in as a doc enhancement request to better explain the global and TX profiles.
  • Martin AA6E
    edited January 2020
    Thanks.  A table of what is in a TX profile and what is in a Global profile would go a long way!
    It would be a nice step forward if the exported profiles were in a human readable format like XML.  Failing that, you could provide an off-line utility to view and/or edit (and validate) profiles.
  • Martin AA6E
    edited January 2020
    @Ed - Just the thing.  Can understand most of the fields, at least.  Thanks!
  • K1ESE
    K1ESE Member ✭✭✭
    edited December 2017
    I don't see CW-U or CW-L being saved?
    73 de K1ESE
    John
  • Martin AA6E
    edited January 2020
    Global / Slice/ Mode  (I suppose).
  • Ed.G
    Ed.G FlexRadio Employee ✭✭
    edited December 2016
    Correct. Our current thinking is that CWL and CWU is a radio wide setting that should not be stored in profiles.
