What's in profiles?
Martin AA6E
Member ✭✭✭
I would like to understand exactly what data are stored in profiles, both Global and Transmit. The Software User's Guide gives a nice table of what parameters are set by "Persistence", but only vague information about profiles.
One example: Where is the transmit bandpass info kept? I need to switch this often when moving from JT65 to SSB operation, but so far haven't figured out whether I can do this with profiles.
I think the question would be more easily answered on what is NOT
stored in profiles. I have asked this same question, also.Jim, K6QE
Your question has been asked many times before.
I would say do a search but with the new software release the items have changed.
Example currently EQ settings are stored with older software version they weren't.
Ian
I have entered this report in as a doc enhancement request to better explain the global and TX profiles.
Thanks. A table of what is in a TX profile and what is in a Global profile would go a long way!
It would be a nice step forward if the exported profiles were in a human readable format like XML. Failing that, you could provide an off-line utility to view and/or edit (and validate) profiles.
Although there will be a couple of new included fields in v1.5, below are two images showing tables of the current settings stored in Transmit and Global profiles. Note that each Global profile has a reference to a Transmit profile that is loaded concurrently with the Global profile.
7 -
@Ed - Just the thing. Can understand most of the fields, at least. Thanks!
I don't see CW-U or CW-L being saved?
73 de K1ESE
John1 -
Global / Slice/ Mode (I suppose).
Correct. Our current thinking is that CWL and CWU is a radio wide setting that should not be stored in profiles.0
- 685 The Flea Market
