Memory in 6000 series software
I would have to agree, memory still needs some work but its getting there.0
Agreed... the memory function is Clunky at best. It may lag behind other features in priority, but
I think memory improvement is important. Yes... there is additional memory software out there, but the radio should still function smoothly on it's own.
Ken, but SSDR has it on board : SSDR Manual, section 20.1, works fine by the way.
You're right of course, Sergey. SSDR memory and FRStack both work quite
well, but what we would like are some memory buttons on the SSDR main
screen, so we wouldn't have to click around. Quick memory and some fast
memory buttons are a must on modern TRX.
Alex you right, however plenty of buttons into one GUI like for ANAN ex. (IMHO) make the screen surface complicated to utilize with other sorts of SW. The best case is of course to implement everything with dockable DUI with functions block, but it required to redesign SSDR GUI completely(or to make one more separate SW like CAT SSDR but for some specific most wanted functions), even 5k some time are not enought :-)
Sergey, as you pointed out there are several add ons for memory function . I'd still like the on board memory function improved though. Why not a drop down tab or button that shows quick buttons for memory etc, as earlier suggested. Also as Dave mentioned... the screen should at least close after a memory is selected. All in good time I'm sure. I find the current memory system noticeably lacking.
You have my vote, Ken :-)
Ken i can agree with drop down tab it will be suitable for use in the same way like profiles for today but additional separate Tab as ex.: CWX or Menu from the Right on SSDR will be too much for GUI.0
Sergey,
Here is a memory button idea that was submitted a while back. It has 9 votes so far and is "under consideration."
https://community.flexradio.com/flexradio/topics/_quick_memories_for_smart_sdr
Does this do what you want?
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
******** snapshot for the idea showing the save and recall panel **********
4 -
That seems like a really good idea to me. it has my vote.
Bill
How about one of the F-keys we should be able to assign short cuts to them0
Maybe someday ill understand Flex's way of thinking, I sure don't now.
4 complicated Noise reductions buttons and no Squelch.... don't get it.
Memory so very limited ...don't get it.
I fail to see Flex's way because and memory is the simple stuff.
Someone please explain what I'm missing......
@DAVE Simple Answer. Use Cases , Customer Demand and availability of programming resources. The target market for the top end radios are DXer and Contesters who need very sophisticated noise tools and rarely use squelch or memory. For example as a DXer and Contester for 55+ years I have never used squelch and except for 60M and 10M FM never used memories But then I rarely if ever rag chew or play with Nets. When resources are available then I suspect FRS will get around to incorporating lower priority features. In the meantime 3rd party app FRstack already does most of what you want. BTW. You continually post about squelch. I think FRS has already heard you but I don't see a lot of other requests for it.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
