FlexControl with v1.4.16
Thanks for your response Neal.
Yes I have. It has not been assigned a port that is in use. I have looked at all "ghost" ports and there are no duplicates. I have reloaded SmartSDR in case the drivers didn't load properly.
K9SO
If you send me an email ar nealk3nc@gmail.com I will be happy to conect to your computer and take a look!0
Thanks for the offer Neal, but we weren't able to hook up tonight. I've changed the port number just in case and that still didn't work.
I've opened a ticket on the issue.
Fred
K9SO0 -
in the new version .16 there is a problem with picking up the flexcontrol. I never had a problem before the update. Now i have to refresh the device manager many times before it picks up. the port has not been changed. It works after some plugging in and refreshing at each boot now.0
Yes thats my quick work around too0
Go to Settings>Radio and Disable FlexControl for a few seconds, then Enable it again. It works every time on my 6500. But I must do it every time I shut down SSDR and restart it.0
The Flex control problem is a known issue, They are working on it...0
Update on Fred's Issue: The FC was disabled in the SmartSDR setup form, which is why it would not connect.
- 369 Community Topics
- 628 The Flea Market
- 84 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 243 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 915 Genius Products
- 332 Tuner Genius XL
- 450 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
