I continue to get Unhandled Errors when launching SSDR. Here's the latest one which I get over half
William Hein
I continue to get Unhandled Errors when launching SSDR. Here's the latest one which I get over half the time when starting SSDR
I've also noticed FlexControl no longer works. I don't know if these problems are related to my upgrade to v.1.4.16 but I don't recall them from prior
Bill AA7XT
Bill AA7XT
Now that I am retired, I think I will look for a part-time job writing error messages for Windows. Not that I know that much about software because I don't. But I am sure that I could throw a bunch of words together and confuse people at least as much as Microsoft does.
Just guessing, but since you mentioned an issue with your Flex Control, I would fire up Device Manager and see what's going on with your COM/USB ports. It sounds like there may be a conflict where WIndows is trying to assign multiple devices to the same port.
Not sure but it could be that the flex control and one of the CAT ports that SmartSDR is trying to use are fighting for the same COM port. Try unplugging the Flex Control and see if you keep getting the "Serial.IO.Ports.SerialStream.EventLoopRunner" error when you start SmartSDR. If it starts correctly after several tries then you may have to change the Flex controllers COM port manually. I think I remember something about this in the release notes and you had to remove the FLEX Control COM port BEFORE installing SmartSDR, I think this has been the same warning in the last 2 version updates about the Flex controller. Just a thought and something to try over the weekend until the FLEX guys get back on Monday to comment 73's Bret WX7Y0
I had same problem a few days ago. Unplug Flex Control. Then had to go into device manager and delete all of the comports. Then plug Flex Control back in and restart SmartSDR. Problem solved.
Bill
VA3QB0 -
That's exactly the problem I am getting, it didn't happen until I updated to version 16. I am out most of today but will try a few of the suggestions when I get back. My Flex Control hasn't worked since I updated.
73, Bill
I have started getting these errors with the previous version. N1MM gives me a duplicate com port error. Will try to fix today.0
If Windows updates this happens.... Windows is bad at com port selections .
This is a previously reported issue that is related to the interaction of the USB com port on the FlexControl and SmartSDR. Being that it is intermittent, does not affect everyone and is mangled up in the (poor) way Windows interacts with non-hardware UARTS, it makes finding root cause challanging. We are working on identifying root cause in order to implement a fix.
In the mean time, try plugging the FlexControl into a different USB port, removing ghosted virtual com ports (https://helpdesk.flexradio.com/hc/en-us/articles/200883925-Removing-Hidden-or-Ghosted-Com-ports) and you can try changing the FlexControl's com port number to a higher values. like 200 (https://helpdesk.flexradio.com/hc/en-us/articles/202479329-How-to-Change-the-Com-Port-Assignment-for...).
Actually, it's a super good error message if you're a programmer familiar with C# ... If you're a "normal" person, not so much.
The problem, in layyman's terms, is the program is trying to read from a COM port, and the COM port it's trying to read from has been closed. This can happen, for example, when you unplug -- or even nudge -- a USB serial adapter. Even a very momentary disconnect of the USB device will cause the problem, due to the way USB work.
This is a very common problem, and IIRC is rather hard to fix as I seem to recall that the exception that's raised is not catchable. That means that calling WaitForCommEvent in a TRY block (the typical fix for this class I
Of issue) may not help.
Bottom line: Problem inherent in the cross product of USB and serial ports, and the lousy COM port handling in the .Net runtime.
Peter
K1PGV0 -
I tried this. Moved FlexControl to COM 222, I haven't seen the startup crash since however FlexControl is still not working. See following screen caps.
I would not set the comport in Cat, let windows assign it before you open SmartSDR. Then go to Device Manager (DM) and change it there to want you want.
But first go to DM and delete all the comports first. Then plug the Flex Control into the USB port on your computer.
Bill
VA3QB0 -
AMEN! We are actively debugging this issue and are "discovering" lots of quirky behavior with the ,NET serial port class. We are confident we'll get to the bottom of this. It just might take a little time.1 -
Thanks Tim, windows never did properly handle USB / com porting.0
Tim, while FRS is in the USB/Serial area, how about including support for dual switch closure USB (CW paddle) or keying via N1MM, or both so we can shake out any bugs before Maestro.
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
