FreeDV installer Error
Ricky Marsh
When i have tried to install the FreeDV i receive the following error.
there is a problem with this windows installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor.
i have re-downloaded but no Joy.
i am using Windows 8.1
Flex 6300
thanks for any help.
Ricky
Flex 6300
Ricky
Did you upgrade to 1.4.11 first?
Yes i have upgraded to 1.4.11 but this does not relate to SmartSDR it is windows that will not let it install and is reporting a DLL will not run. i have not even started the waveform installation so i was wondering if anyone has managed to install under the windows 8.1 environment.
I have installed the FreeDV_Waveform_Installer.msi on Windows 8.1 Pro using a Surface Pro 2 without any problem.0
Thanks so now i know its a problem my end, i will try it on another laptop.
Thanks for your help.
I have now solved this problem and installed FreeDV there was a permissions issue after going to
properties ; Securityon theC:UsersxAppDataLocalTempfolder and giving thatEveryonetheFull controlall now installs.
hopefully no one has the same problem.
Ricky0
- 378 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 260 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
