FreeDV installer Error
Ricky Marsh
When i have tried to install the FreeDV i receive the following error.
there is a problem with this windows installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor.
i have re-downloaded but no Joy.
i am using Windows 8.1
Flex 6300
thanks for any help.
Ricky
Flex 6300
Ricky
Did you upgrade to 1.4.11 first?
Yes i have upgraded to 1.4.11 but this does not relate to SmartSDR it is windows that will not let it install and is reporting a DLL will not run. i have not even started the waveform installation so i was wondering if anyone has managed to install under the windows 8.1 environment.
I have installed the FreeDV_Waveform_Installer.msi on Windows 8.1 Pro using a Surface Pro 2 without any problem.0
Thanks so now i know its a problem my end, i will try it on another laptop.
Thanks for your help.
I have now solved this problem and installed FreeDV there was a permissions issue after going to
properties ; Security
on theC:UsersxAppDataLocalTemp
folder and giving thatEveryone
theFull control
all now installs.
hopefully no one has the same problem.
Ricky0
- 255 Community Topics
- 491 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 789 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 737 Genius Products
- 394 Power Genius XL Amplifier
- 256 Tuner Genius XL
- 87 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 588 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 815 Third-Party Software
