smartSDR v1.4.11 DAX error
Takeshi Yamada
After installing v1.4.11 over v1.4.3, I have the following DAX error. (Tried to clear all and reinstall still gives the same error.)
Any fix?
Any fix?
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
I saw that too, but I upgraded over remote desktop, so I figured when DAX tried to start back up, the audio devices weren't available (because remote desktop has audio limitations). I'll play around some more tonight, but I'm guessing the error I saw wasn't really an error with dax.
Just Installed :
i have NO issue with DAX after 1.4.11 installed:
F6700
Win10 Technical Preview build 10074 running on Parallels on MAC OS Yosemite 10.10.3
NR+ANF works superb even as already reported with 50z in CW !0 -
I finally fixed this by uninstall FlexVSP and SmartSDR from "control panel/program/program and feature", and re-install all. I suspect that some of DAX devise was accidentally assinged as "Default". FlexVSP was not un-installed properly and failed to re-install.
Anyway, now it works and NF and AFP seemingly work much better.
Thank you for your help.
73 de JI1BNU
Ken Yamada1 -
good job, Takeshi-san !1
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
