smartSDR v1.4.11 DAX error
Takeshi Yamada
Takeshi Yamada Member ✭✭
edited June 2019 in SmartSDR for Windows
After installing v1.4.11 over v1.4.3, I have the following DAX error.  (Tried to clear all and reinstall still gives the same error.)
Any fix?
    edited March 2017
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
  • rfoust
    rfoust Member ✭✭
    edited March 2017
    I saw that too, but I upgraded over remote desktop, so I figured when DAX tried to start back up, the audio devices weren't available (because remote desktop has audio limitations).  I'll play around some more tonight, but I'm guessing the error I saw wasn't really an error with dax.
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Just Installed :
    i have NO issue with DAX after 1.4.11 installed:
    F6700
    Win10 Technical Preview build 10074 running on Parallels on MAC OS Yosemite 10.10.3
    NR+ANF works superb even as already reported with 50z in CW !
  • Takeshi Yamada
    edited June 2019
    I finally fixed this by uninstall FlexVSP and SmartSDR from "control panel/program/program and feature", and re-install all.   I suspect that some of DAX devise was accidentally assinged as "Default".   FlexVSP was not un-installed properly and failed to re-install.
    Anyway, now it works and NF and AFP seemingly work much better.
    Thank you for your help.
    73 de JI1BNU
    Ken Yamada
  • W5XZ - dan
    W5XZ - dan Member ✭✭
    edited December 2016
    good job, Takeshi-san !1
