SmartSDR API - Transmit object: sb_monitor property vs monitor property
IW7DMH, Enzo
Hello,
I am wondering which is the difference between the two properties I found in the transmit status response.
Actually I have the following issue: when my client starts, in the very first status message it gets the following transmit status message:
SA37CD239|transmit freq=14.03595 lo=50 hi=2800 tx_filter_changes_allowed=1 tx_rf_power_changes_allowed=1 rfpower=90 tunepower=10 am_carrier_level=86 vox_enable=0 vox_level=50 vox_delay=22 mic_level=34 mic_selection=MIC mic_boost=1 mic_bias=0 mic_acc=0 compander=1 compander_level=70 dax=0 pitch=500 speed=20 iambic=1 iambic_mode=1 cwl_enabled=0 swap_paddles=0 synccwx=1 break_in=1 break_in_delay=9 sidetone=1 monitor=0 mon_gain_cw=74 mon_gain_sb=72 mon_pan_cw=50 mon_pan_sb=50 tune=0 met_in_rx=0 hwalc_enabled=0 inhibit=0 speech_processor_enable=1 speech_processor_level=0 show_tx_in_waterfall=1 mon_available=1
As you can see there is only the monitor property but the sb_monitor property is missing, so I can't get the initial monitor button status. I had to switch to USB or any other phone mode to get the sb_monitor property and get the button status.
Below there is the second status message I receive when I switch to USB and here I can finally find the sb_monitor value.
S906A7230|transmit mic_level=34 mic_selection=MIC mic_boost=1 mic_bias=0 mic_acc=0 compander=1 compander_level=70 dax=0 sb_monitor=0 mon_gain_cw=74 mon_gain_sb=72 mon_pan_cw=50 mon_pan_sb=50 met_in_rx=0 show_tx_in_waterfall=1 mon_available=1
I am wondering if there is another way to get the sb_monitor property or if it is a missing property that should be in every transmit status message.
Thank you very much and 73'
Enzo
iw7dmh
Enzo
iw7dmh
Good find. This is actually a bug in that status message. Today it will always return monitor=0. It really should refer to sb_monitor. We will get this corrected in a future release. Thanks for pointing this out. (#2013)
Side note: There are several different versions of the transmit status message depending on the context and not all of them are guaranteed to include the sb_monitor token.0 -
Yes, I am aware of it, and my code take it into account.
Thank you very much for your help and thank a lot for the more frequent SSDR releases.
Today I verified that every bug I got in the previous version has been fixed with 1.4.11.
You are a great team.
73' Enzo
iw7dmh
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
