Mic bias selection
Stewart Rolfe
On my Flex 6300 there is 5v on pin 2 of the front mic connector irrespective of whether the 'BIAS' button on the Transmit is window is selected or not - is this normal?
Yes, Pin 2 is +5 volts, bias turns voltage on pin 1. 73 s Jim K4JAF0
Posting this brought up thread on the SSDR category which appears to answer this...sorry for the qrm - must check the frequency before transmitting.
Stew, GW0ETF0 -
Actually, the microphone hot lead is on pin 8, according to other posts from Gerald and Tim, W4TME, not pin 1. The bias of 2.97 VDC would thus be applied to pin 8 when activated via the GUI.0
Yes pin 8 is correct Mic pin. Yaesu (Flex) uses pin 8 not 1.
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 774 Maestro
- 42 FlexControl
- 728 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
