Mic bias selection
Stewart Rolfe
On my Flex 6300 there is 5v on pin 2 of the front mic connector irrespective of whether the 'BIAS' button on the Transmit is window is selected or not - is this normal?
Yes, Pin 2 is +5 volts, bias turns voltage on pin 1. 73 s Jim K4JAF0
Posting this brought up thread on the SSDR category which appears to answer this...sorry for the qrm - must check the frequency before transmitting.
Stew, GW0ETF0 -
Actually, the microphone hot lead is on pin 8, according to other posts from Gerald and Tim, W4TME, not pin 1. The bias of 2.97 VDC would thus be applied to pin 8 when activated via the GUI.0
Yes pin 8 is correct Mic pin. Yaesu (Flex) uses pin 8 not 1.
- 393 Community Topics
- 669 The Flea Market
- 174 SmartSDR+
- 452 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 75 Aurora
- 318 FLEX-8000 Signature Series
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 834 Peripherals & Station Integration
- 146 Amateur Radio Interests
